Maniphest T76398
Blender crashes when UNDO in Graph Editor in pose mode.
Closed, Archived
Ankit Meel (ankitm)
Kamil Adamski (adrian2608)
May 4 2020, 1:12 PM
  • BF Blender
Ankit Meel (ankitm)
Bastien Montagne (mont29)
Brecht Van Lommel (brecht)
Operating system:
Graphics card: RTX 2070S
Broken: Newest from Graphicall.
Worked: None.
I can't be sure, because it's not always occur, but rather often. And it doesn't quite go about Graph Editor Imo pose mode.
Just, when You want to UNDO for example badly positioned bone blender crashes. And this behaviour isn't fresh. It's since I remember, so maybe even from the beginning of 2.70 series. Maybe even earlier.
In pose mode of a more complicated rig, like AutoRig, or just rigify, try to undo bone placement. Can't attach blend, because the file is too large, also it's copyrighted because it's from job.
Kamil Adamski (adrian2608) created this task.May 4 2020, 1:12 PM
Eitan Traurig (EitanSomething) added a subscriber: Bastien Montagne (mont29).May 4 2020, 3:27 PM
Kamil Adamski (adrian2608) added a comment.May 4 2020, 6:22 PM
I was testing it a bit more aware, and it occurs all the time. This is a critical bug, because You can't undo bone placement.
Brecht Van Lommel (brecht) changed the task status from Needs Triage to Needs Information from User.May 4 2020, 7:15 PM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Please test a build from builder.blender.org and specify the exact version tested (easiest when using Help > Report a Bug in Blender).
https://builder.blender.org/download/
Further, we require a .blend file with steps to reproduce the problem. If you can reproduce the problem with rigify for example, attach a .blend file created that way.
Ankit Meel (ankitm) closed this task as Archived.May 12 2020, 1:44 PM
Ankit Meel (ankitm) claimed this task.
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
related, but no crash though, T76590: New undo in 2.83 causes armature to disappear from viewport and seemingly makes it permanently invisible
