Operating system: Linux-5.3.0-51-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1050/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 440.59
CUDA: 10.2
Broken: version: 2.83 (sub 13), branch: master, commit date: 2020-04-13 08:07, hash: rB2ec6eca518ef
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-05-03 18:42, hash: rB331bf04fad93
Worked: version: 2.83 (sub 11), branch: master, commit date: 2020-03-31 23:07, hash: rBda3cb514e52d
Blender crashes (Segmentation Fault) while trying to use cupy.
It will pass the first three flags and then segfault before the fourth.
From the command line use blender --background --python CudaTest.py
This will throw a seg fault
If you run the same script outside of blender:
$(BLENDER_DIR)/2.83/python/bin/python3.7m CudaTest.py
The code will run normally.
Environment setup
Assuming CUDA is installed normally and from a fresh blender install:
$(BLENDER_DIR)/2.83/python/bin/python3.7m -m ensurepip
$(BLENDER_DIR)/2.83/python/bin/python3.7m -m pip install cupy-cuda102
Much appreciation
Really appreciate your help! Thanks and hope everyone is staying safe!
Other information
Example backtrace of the core dump below.
#0 0x000000000d555b20 in nvrtcVersion ()
#1 0x00007fca78ca297d in pyx_f_4cupy_4cuda_5nvrtc_getVersion (pyx_skip_dispatch=<optimized out>)
at cupy/cuda/nvrtc.cpp:1923
#2 0x00007fca78ca2afb in pyx_pf_4cupy_4cuda_5nvrtc_2getVersion (pyx_self=<optimized out>)
at cupy/cuda/nvrtc.cpp:2021
#3 pyx_pw_4cupy_4cuda_5nvrtc_3getVersion (pyx_self=<optimized out>, unused=<optimized out>)
at cupy/cuda/nvrtc.cpp:2008
#4 0x0000000005700a20 in _PyMethodDef_RawFastCallKeywords ()
#5 0x0000000005700ab5 in _PyCFunction_FastCallKeywords ()
#6 0x0000000000c0d098 in _PyEval_EvalFrameDefault ()
#7 0x0000000000c04b80 in ?? ()
#8 0x0000000000c0e8fe in _PyEval_EvalFrameDefault ()
#9 0x0000000000c04b80 in ?? ()
#10 0x0000000000c0e8fe in _PyEval_EvalFrameDefault ()
#11 0x00000000057b244c in _PyEval_EvalCodeWithName ()
#12 0x0000000005700536 in _PyFunction_FastCallKeywords ()
#13 0x0000000000c0e8fe in _PyEval_EvalFrameDefault ()
#14 0x00000000057b244c in _PyEval_EvalCodeWithName ()
#15 0x0000000005700380 in _PyFunction_FastCallDict ()
#16 0x00007fcaa487fe57 in __Pyx_PyObject_Call (kw=0x7fca5234b0a0, arg=0x7fca523e7980, func=<optimized out>)
at cupy/core/core.cpp:53653
#17 pyx_f_4cupy_4core_4core_compile_with_cache (pyx_v_source=0x7fca5247e1d0,
pyx_skip_dispatch=<optimized out>, pyx_optional_args=<optimized out>) at cupy/core/core.cpp:35823
#18 0x00007fca703887a1 in pyx_f_4cupy_4core_7_kernelget_simple_elementwise_kernel (
pyx_v_params=0x7fca527131e0, pyx_v_arginfos=0x7fca5234b910, pyx_v_operation=0x7fca5233d2d0,
pyx_v_name=0x7fca5277d490, pyx_v_type_map=<optimized out>, pyx_v_preamble=0x7fcae7c0e3b0,
pyx_skip_dispatch=0, pyx_optional_args=0x7ffdf824d010) at cupy/core/_kernel.cpp:4481
#19 0x00007fca70389127 in pyx_pf_4cupy_4core_7_kernel_2_get_simple_elementwise_kernel (
pyx_v_options=<optimized out>, pyx_v_after_loop=<optimized out>, pyx_v_loop_prep=0x7fcae7c0e3b0,
pyx_v_preamble=<optimized out>, pyx_v_type_map=<optimized out>, pyx_v_name=0x7fca5277d490,
pyx_v_operation=0x7fca5233d2d0, pyx_v_arginfos=0x7fca5234b910, pyx_v_params=0x7fca527131e0,
pyx_self=<optimized out>) at cupy/core/_kernel.cpp:4711
#20 pyx_pw_4cupy_4core_7_kernel_3_get_simple_elementwise_kernel (pyx_self=<optimized out>,
pyx_args=<optimized out>, pyx_kwds=<optimized out>) at cupy/core/_kernel.cpp:4681
#21 0x0000000005702705 in PyCFunction_Call ()
#22 0x00007fca703860ff in Pyx_PyObject_Call (kw=0x7fca52348500, arg=0x7fca523e78a0, func=0x7fca79748500)
at cupy/core/_kernel.cpp:36022
#23 pyx_pf_4cupy_4core_7_kernel_12_get_elementwise_kernel (pyx_v_kwargs=0x7fca52348500,
pyx_v_preamble=0x7fcae7c0e3b0, pyx_v_name=0x7fca5277d490, pyx_v_operation=0x7fca5233d2d0,
pyx_v_params=0x7fca527131e0, pyx_v_type_map=0x7fcaa4af4750, pyx_v_arginfos=0x7fca5234b910,
pyx_self=<optimized out>) at cupy/core/_kernel.cpp:15617
#24 pyx_pw_4cupy_4core_7_kernel_13_get_elementwise_kernel (__pyx_self=<optimized out>,
pyx_args=<optimized out>, pyx_kwds=<optimized out>) at cupy/core/_kernel.cpp:15281
#25 0x0000000005702705 in PyCFunction_Call ()
#26 0x00007fca862468a7 in Pyx_PyObject_Call (kw=0x7fca52344eb0, arg=0x7fca523e77c0, func=0x7fca7975a410)
at cupy/util.cpp:4384
#27 pyx_pf_4cupy_4util_7memoize_9decorator_ret (pyx_v_kwargs=0x7fca52344eb0, pyx_v_args=0x7fca523e77c0,
pyx_self=<optimized out>) at cupy/util.cpp:2016
#28 pyx_pw_4cupy_4util_7memoize_9decorator_1ret (pyx_self=<optimized out>, pyx_args=0x7fca523e77c0,
pyx_kwds=<optimized out>) at cupy/util.cpp:1831
#29 0x00007fca703587f5 in Pyx_PyObject_Call (func=0x7fca7975e050, arg=0x7fca523e77c0, kw=0x7fca52709730)
#30 0x00007fca70361fa3 in pyx_f_4cupy_4core_7_kernel_17ElementwiseKernelget_elementwise_kernel (
pyx_v_self=0x7fca52711d60, pyx_v_dev_id=<optimized out>, pyx_v_arginfos=0x7fca5234b910,
pyx_v_type_map=0x7fcaa4af4750, pyx_skip_dispatch=<optimized out>) at cupy/core/_kernel.cpp:17938
#31 0x00007fca70379f9f in pyx_pf_4cupy_4core_7_kernel_17ElementwiseKernel_2call (
pyx_v_kwargs=0x7fcabe957690, pyx_v_args=0x7fcabe953b50, pyx_v_self=0x7fca52711d60)
at cupy/core/_kernel.cpp:17297
#32 pyx_pw_4cupy_4core_7_kernel_17ElementwiseKernel_3call (pyx_v_self=0x7fca52711d60,
pyx_args=0x7fcabe953b50, __pyx_kwds=<optimized out>) at cupy/core/_kernel.cpp:16373
#33 0x0000000005700bd4 in _PyObject_FastCallKeywords ()
#34 0x0000000000c0ca72 in _PyEval_EvalFrameDefault ()
#35 0x00000000057b244c in _PyEval_EvalCodeWithName ()
pyx_args=0x7fcabe953b50, pyx_kwds=<optimized out>) at cupy/core/_kernel.cpp:16373
#36 0x0000000005700536 in _PyFunction_FastCallKeywords ()
#37 0x0000000000c0dd52 in _PyEval_EvalFrameDefault ()
#38 0x00000000057b244c in _PyEval_EvalCodeWithName ()
#39 0x0000000005700536 in _PyFunction_FastCallKeywords ()
#40 0x0000000000c0e50c in _PyEval_EvalFrameDefault ()
#41 0x00000000057b244c in _PyEval_EvalCodeWithName ()
#42 0x00000000057b257e in PyEval_EvalCodeEx ()
#43 0x00000000057b25ab in PyEval_EvalCode ()
#44 0x00000000057e57a2 in PyRun_FileExFlags ()
#45 0x00000000011ec931 in ?? ()
#46 0x0000000000c10ab8 in _start ()
