Maniphest T76430
Quick smoke not rendering Cycles and Eevee
Closed, ResolvedBUG
Sebastián Barschkis (sebbas)
Scott VanKirk (svankirk)
May 5 2020, 4:28 AM
  • BF Blender
  • Nodes & Physics
  • Physics
Philipp Oeser (lichtwerk)
Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.83 (sub 15), branch: master, commit date: 2020-05-04 21:58, hash: rBd8133b3eb99a
unknown
Quick smoke render on frame > 1 of simulation does not render.
new file
create default plane
apply quick smoke
at this point the smoke shows in all views and in a render.
optionally: save blend file.
move to frame 2 - smoke shows in all views, but not on render. Expected: smoke renders as normal
move to frame 1 - again, smoke does not show in render.
This happens with Cycles and Eeevee
if you save the blend file it does not change this behavior. If you bake the simulation, it does not render. If you change the blackbody intensity in the shader, it does not render. If you promise your first born to Satan, it does not render.
I have not figured out how to get it to render at all after this.
UPDATE: smoke will render if you exit and re-open the file.
File:
Revisions and Commits
rB Blender
Related Objects
Mentioned In
T76312: Liquid simulation Particle/Mesh vanishes - Only Domain is rendered
Mentioned Here
rB8d5ae15040ed: Fluid: Fixes for cache 'Replay' mode
Scott VanKirk (svankirk) created this task.May 5 2020, 4:28 AM
Eitan Traurig (EitanSomething) added a project: Nodes & Physics.May 5 2020, 4:28 AM
Scott VanKirk (svankirk) renamed this task from Quick smoke not rendering to Quick smoke not rendering Cycles and Eevee.May 5 2020, 4:31 AM
Scott VanKirk (svankirk) updated the task description.
Scott VanKirk (svankirk) added a project: Physics.
Scott VanKirk (svankirk) updated the task description.May 5 2020, 4:58 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.May 5 2020, 10:02 AM
Can confirm.
Philipp Oeser (lichtwerk) triaged this task as High priority.May 5 2020, 10:35 AM
Philipp Oeser (lichtwerk) added a subscriber: Sebastián Barschkis (sebbas).
Caused by rB8d5ae15040ed: Fluid: Fixes for cache 'Replay' mode
CC @Sebastián Barschkis (sebbas)
Sebastián Barschkis (sebbas) added a comment.May 5 2020, 11:22 AM
Ah I see, thx, looking into this problem right now!
Sebastián Barschkis (sebbas) closed this task as Resolved by committing rB11d440f1a261: Fix T76430: Quick smoke not rendering Cycles and Eevee.May 6 2020, 1:25 PM
Sebastián Barschkis (sebbas) claimed this task.
Sebastián Barschkis (sebbas) added a commit: rB11d440f1a261: Fix T76430: Quick smoke not rendering Cycles and Eevee.
Sebastián Barschkis (sebbas) added a comment.May 6 2020, 1:38 PM
Since this is a critical bug I pushed a temporary fix. Rendering should work now, the only downside is that changing parameters from flow / effector objects will not invalidate the cache.
