Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.19
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-02-12 16:20, hash: rB77d23b0bd76f
I reported this as a papercut on the devtalk with some suggestions for improvements but i believe it's more than that. 2.7 had some options to adjust the handles size for the scale and the move tools but in the new 2.8 versions it's now one option that alteres everything.
The rotate tool is fine as it doens't have handles but the other two become too big for what's needed when i put the max value as you can see. the reason for that it makes grabbing the axes much eaiser and Blender has sensitivity for when you get closer to the center which i don't like.
I hope this explains the reasons for why some changes are needed at least for the size of the handles.
Thank you.
Open the Preferences editor and in the viewport tab under the gizmo size panel make the value to high or max then switch between the transform tools.
PS: is there a way to disable the outer scale circle? i use click drag anywhere with the right click select.
