Maniphest T76512
Sculpt mode: crash when applying base
Closed, ResolvedBUG
Sergey Sharybin (sergey)
Erick Tukuniata (erickblender)
May 7 2020, 6:01 PM
  • BF Blender
  • Sculpt, Paint & Texture
  • Modifiers
Ankit Meel (ankitm)
Philipp Oeser (lichtwerk)
Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 376.54
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-05-07 13:14, hash: rB7181342e6285
With default settings:
  • Go to sculpt mode
  • Add Multires on the Cube
  • Subdivide it 3 times
  • Click on rebuild subdivision, then
  • Click on apply base, it should here.
Revisions and Commits
rB Blender
D7663
Erick Tukuniata (erickblender) created this task.May 7 2020, 6:01 PM
Eitan Traurig (EitanSomething) added a project: Sculpt, Paint & Texture.May 7 2020, 7:16 PM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).May 7 2020, 7:30 PM
Cannot reproduce here.
You mean in editmode? Or via the Multires modifier? (doing it via the Multires modifier wouldnt make sense? rebuilding subdivisions on the default cube [with modifier] gives me "Not valid subdivisions found to rebuild lower levels")
If I do it in editmode [or apply the multires subdivisions, add another Multires modifier], then rebuild subdivision, then apply base, I dont get a crash.
Erick Tukuniata (erickblender) added a comment.May 7 2020, 7:54 PM
I assume that you cannot reproduce after you have done your second scenario ( Subdivide in edit mode ) I am correct? If yes did you try it with multires. subdivision?
In sculpt mode with multires subdivision.
For the reasoning behind the crash. The step defined above are not logical at all because i have discovered it by mistake. While working i clicked, by mistake, rebuild subdivision when i was planning to click apply base and then just after it click the Apply Base then the crash.
Erick Tukuniata (erickblender) updated the task description.May 7 2020, 7:57 PM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).May 7 2020, 8:03 PM
Ankit Meel (ankitm) added a comment.May 7 2020, 8:05 PM
Just checked your reply (hadn't refreshed)
Yes I get a crash, despite
at step "rebuild subdivisions"
Ankit Meel (ankitm) changed the task status from Needs Triage to Confirmed.May 7 2020, 8:10 PM
Ankit Meel (ankitm) added a project: Modifiers.
#0	 in pbvh_iter_begin at 		blender/source/blender/blenkernel/intern/pbvh.c:735
#1	 in BKE_pbvh_search_gather at 		blender/source/blender/blenkernel/intern/pbvh.c:846
#2	 in sculpt_undo_push_all_grids at 		blender/source/blender/editors/sculpt_paint/sculpt_undo.c:1571
#3	 in ED_sculpt_undo_push_multires_mesh_begin at 		blender/source/blender/editors/sculpt_paint/sculpt_undo.c:1593
#4	 in multires_base_apply_exec at 		blender/source/blender/editors/object/object_modifier.c:1729
#5	 in multires_base_apply_invoke at 		blender/source/blender/editors/object/object_modifier.c:1744
#6	 in wm_operator_invoke at 		blender/source/blender/windowmanager/intern/wm_event_system.c:1271
#7	 in wm_operator_call_internal at 		blender/source/blender/windowmanager/intern/wm_event_system.c:1519
#8	 in WM_operator_name_call_ptr at 		blender/source/blender/windowmanager/intern/wm_event_system.c:1533
#9	 in ui_apply_but_funcs_after at 		blender/source/blender/editors/interface/interface_handlers.c:887
#10	 in ui_handler_region_menu at 		blender/source/blender/editors/interface/interface_handlers.c:10692
#11	 in wm_handler_ui_call at 		blender/source/blender/windowmanager/intern/wm_event_system.c:617
#12	 in wm_handlers_do_intern at 		blender/source/blender/windowmanager/intern/wm_event_system.c:2725
#13	 in wm_handlers_do at 		blender/source/blender/windowmanager/intern/wm_event_system.c:2836
#14	 in wm_event_do_handlers at 		blender/source/blender/windowmanager/intern/wm_event_system.c:3231
#15	 in WM_main at 		blender/source/blender/windowmanager/intern/wm.c:450
#16	 in main at 		blender/source/creator/creator.c:528
Philipp Oeser (lichtwerk) added a comment.May 7 2020, 8:12 PM
ok, get it now, too [was not in sculptmode...]
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "Bug".May 7 2020, 8:12 PM
Sergey Sharybin (sergey) claimed this task.May 8 2020, 3:29 PM
Sergey Sharybin (sergey) added a revision: D7663: Fix T76512: Sculpt mode: crash when applying base.
Sergey Sharybin (sergey) closed this task as Resolved by committing rB86a16e7381ae: Fix T76512: Sculpt mode: crash when applying base.May 11 2020, 3:32 PM
Sergey Sharybin (sergey) added a commit: rB86a16e7381ae: Fix T76512: Sculpt mode: crash when applying base.
