Operating system: Darwin-19.4.0-x86_64-i386-64bit 64 Bits
Graphics card: Intel Iris Pro OpenGL Engine Intel Inc. 4.1 INTEL-14.5.22
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
When trying to move e.g. edges in Blender, the manipulator widget (the thing with the colored axes that lets you drag edges and vertices) often does not appear in the "right" place.
Sometimes the widget appears right next to the edge/vertex you're moving (good!) and sometimes it appears only in the middle of the object (bad, when the object is large and you're trying to position accurately!).
I have tried e.g. setting the object origin to the 3d cursor with the cursor positioned next to the edge or vertex I'm trying to move, but that approach hardly ever works.
In short, the manipulator widget is problematic or outright broken in many cases, rendering it useless.
- Delete all default objects
- Create a plane
- Go to edit mode
- Activate the Move Tool to see the gizmo
- Set the Pivot Transform Point to Active Element
- Go to face selection mode and activate the face
- Go to vertex selection mode and select two vertices of an edge
- Go to edge selection mode
Now notice that the pivot point is in the middle of the face despite the selected edge.
