Maniphest T76644
eevvee, render and rendered the result is weird
Closed, Archived
Ankit Meel (ankitm)
yuyun (hahati)
May 11 2020, 2:14 PM
  • BF Blender
Ankit Meel (ankitm)
Brecht Van Lommel (brecht)
Richard Antalik (ISS)
yuyun (hahati)
Operating system: xubuntu 20.04, lmde 4. manjaro 20.0 (all this os, i test, and give same result)
Graphics card: Advanced Micro Devices, Inc. [AMD/ATI] Turks PRO [Radeon HD 6570/7570/8550]
Broken: 2.82 (sub 7),
render and rendered, the lights give weird result (sorry for english)
yuyun (hahati) created this task.May 11 2020, 2:14 PM
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.EditedMay 11 2020, 5:09 PM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
The light power is unusually high, 150,000 W and color is also white, not sure why the reference image is given with color.
what is meant by that ? what is the bug?
yuyun (hahati) added a comment.May 11 2020, 6:07 PM
i dont know too,
are you use linux?
but same pc, if i use windows, no problem with that.
but if use linux (LMDE 4, xubuntu 20.04, manjaro 20.0) the light is annoying, if to low, like no light, but if big, light is not white
may be, if i use xubuntu 19.10 (down grade version) not any problem (may be. i haven't tried it)
i want to test again with fedora 32 (new release) before try the xubuntu 19.10
but if i change the light 15 W, i dont see the white light, if 150 W the light collour is not white,
Ankit Meel (ankitm) changed the task status from Needs Information from User to Needs Triage.May 11 2020, 7:14 PM
yuyun (hahati) added a comment.May 11 2020, 10:15 PM
sory cant give screenshot, new fedora give same result.
i dont know, why in new version from distro "A" to "E" give same result.
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.May 12 2020, 11:21 AM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
@yuyun (hahati) Can you clarify what is exact model of your GPU? Only Radeon HD 8550 would be currently supported GPU.
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).May 12 2020, 4:41 PM
The "Turks" architecture means it's Terascale and so unsupported. There are different HD 8550 variations, some GCN, some Terascale.
Ankit Meel (ankitm) added a comment.May 13 2020, 8:23 AM
T76648#930218 would this workaround work here ?
Ankit Meel (ankitm) closed this task as Archived.May 21 2020, 2:47 PM
Ankit Meel (ankitm) claimed this task.
