Maniphest T76647
transform orientation always uses global. Ignores any other setting (local, normal, gimbal etc)
Closed, Resolved
Germano Cavalcante (mano-wii)
michael campbell (3di)
May 11 2020, 5:34 PM
  • BF Blender
Alaska (Alaska)
Ankit Meel (ankitm)
db (phocomelus)
Ian Smith (mries1999)
Operating system: Windows-10-10.0.17763-SP0 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 442.92
Broken: version: 2.90 (sub 0), branch: master, commit date: 2020-05-10 13:42, hash: rB51ac411ce80c
create cube, rotate it a bit, change to local transform orientation, rotate along z, it still uses global co-ordinates.
Related Objects
Mentioned Here
rB2f63e4793133: Fix T76504: Change in behavior of constraints orientation
michael campbell (3di) created this task.May 11 2020, 5:34 PM
Ankit Meel (ankitm) added subscribers: Ian Smith (mries1999), Ankit Meel (ankitm), Alaska (Alaska).
db (phocomelus) added a subscriber: db (phocomelus).May 11 2020, 6:07 PM
Or is it that you have to press the key for the desired axis a second time now?
Previously it would start on the local/selected orientation and then pressing a second time would go back to global, but now it seems global is first, then local/selected is second key press? It definitely changed in one of the recent builds...
michael campbell (3di) added a comment.May 11 2020, 6:10 PM
lets hope this isn't the case, the selected orientation should always be first.
Germano Cavalcante (mano-wii) closed this task as Resolved.May 11 2020, 6:59 PM
Germano Cavalcante (mano-wii) claimed this task.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
This is how it worked in 2.79, but now I reverted the commit that changed the behavior in 2.83 rB2f63e4793133: Fix T76504: Change in behavior of constraints orientation.
