Maniphest T76670
Moving objects with gizmo crashes blender
Closed, Duplicate
None
Constantine Vojik (costavojik)
May 12 2020, 8:07 AM
  • BF Blender
Alaska (Alaska)
Graphics card: GeForce RTX 2080 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.90 (sub 1), branch: master, commit date: 2020-05-11 15:54, hash: rBdfbb3d82f787
Worked: 2.83
You can move it only with shortcuts
  1. Open blender press T for the tools panel
  2. Select move
  3. Move the default cube
Related Objects
Mentioned Here
rB508124b5bea4: Fix error in last transform orient commit
rB542ff416e274: Fix T76285: Missing 'Toggle X-Ray' operator description
Constantine Vojik (costavojik) created this task.May 12 2020, 8:07 AM
Alaska (Alaska) added a subscriber: Alaska (Alaska).EditedMay 12 2020, 8:16 AM
I'm unable to reproduce it with Blender 2.90 542ff416e274 (2020-05-11 21:02). Between the release you're using and the one I'm using, this patch has been made: 508124b5bea4. I'm not 100% sure as I'm not a programmer, but maybe this has fixed your issue.
Are you able to test the latest 2.90 build from the Blender website and report back with your results.
Alaska (Alaska) changed the task status from Needs Triage to Needs Information from User.May 12 2020, 8:18 AM
Ankit Meel (ankitm) closed this task as a duplicate of T76649: crash by moving an object with gizmos.May 12 2020, 9:00 AM
