Maniphest T76710
Objects can be moved or linked into linked collections (causing them to disappear after file reload)
Closed, ResolvedBUG
Philipp Oeser (lichtwerk)
Alexander Dumproff (A.Lex_3D)
May 13 2020, 8:50 AM
  • BF Blender
  • Pipeline, Assets & I/O
Graphics card: Quadro 5000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 377.83
Broken: version: 2.82 (sub 7), branch: master, commit date: 2020-03-12 05:06, hash: rB375c7dc4caf4
Objects can be linked to linked collections (causing them to disappear after file reload)
The reference file:
... and the file in which the models are referenced:
Steps:
  1. LINK the "SuzanneCollection" from the Reference file in a new, empty file
  2. search for "overide" in the function search box and make a library override
  3. select one of the objects from the list
  4. Delete the SuzanneCollection Empty from the Scene:
  1. Create a Polygon Object in the main Collection "Collection"
  2. Drag this object into the Suzanne Collection:
  1. Save and Reload the File
--> The Cube Object is gone.
Revisions and Commits
rB Blender
Closed
Alexander Dumproff (A.Lex_3D) created this task.May 13 2020, 8:50 AM
Philipp Oeser (lichtwerk) added a project: Pipeline, Assets & I/O.May 13 2020, 9:57 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.May 13 2020, 2:12 PM
It would be good to at least share the library as well as the main .blend file of what you are showing in the video in order to have a chance to reproduce this quickly.
Also please take the time to write down the exact steps to reproduce [having to go through the pixelated video does not help that much here...]
Alexander Dumproff (A.Lex_3D) added a comment.EditedMay 13 2020, 2:43 PM
Ah sorry - here are the files from the video:
The reference file:
Steps:
I was unfortunately not able to reproduce the bug where one of the referenced files was removed and replaced by a copy of one of the other files
In that scenario for example 'Bob' would be missing but 'Lisa' would then be instanced twice (in the same spot).
Reloading the file would then remove more other instances and duplicate 'Lisa' several more times.
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Confirmed.May 13 2020, 3:39 PM
Can confirm.
  • I think we should not be able to drag an object to a linked collection in the outliner?
  • I also think we should not be able to create a new object in a linked collection (adding an object will put it in that linked collection if that collection is selected in the outliner...)
Philipp Oeser (lichtwerk) added a comment.May 13 2020, 3:41 PM
I will constrain this report to your last comments (since the "piling up weird behaviours over time" is a bit too vague...)
Will update the report description accordingly.
Philipp Oeser (lichtwerk) renamed this task from OVerriden Library piling up weird behaviours over time to Objects can be linked to linked collections (causing them to disappear after file reload).May 13 2020, 3:45 PM
Philipp Oeser (lichtwerk) updated the task description.
Bastien Montagne (mont29) moved this task from Backlog to Bugs on the Pipeline, Assets & I/O board.May 13 2020, 3:57 PM
Philipp Oeser (lichtwerk) renamed this task from Objects can be linked to linked collections (causing them to disappear after file reload) to Objects can be moved or linked into linked collections (causing them to disappear after file reload).May 13 2020, 4:04 PM
Philipp Oeser (lichtwerk) claimed this task.May 13 2020, 4:24 PM
Philipp Oeser (lichtwerk) closed this task as Resolved by committing rB0a32f6c8686c: Fix T76710: objects get lost in linked/overridden collections.May 15 2020, 1:46 PM
Philipp Oeser (lichtwerk) added a commit: rB0a32f6c8686c: Fix T76710: objects get lost in linked/overridden collections.
