Operating system: WINDOWS10 LINUX(arch)
Graphics card: NVIDIA 1650
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
2.90.2 blender-2.90-eaf7d36d66e5-windows64
Random Selected faces assigned to a Group - then do a Select (object data properties) returns not the faces assigned to the Group
Default install
SHIFT A Ico-SPHERE subdivisions 5 radius 15
EDIT MODE FACE - SELECT RANDOM
object properties (properties tab) add group - assigned RANDOM SELECTED FACES - ALT A - press SELECT
the FACES selected are not the same as the ones assigned
and some edges are selected.
Tried on linux and Windows 10, version 1909
Cheers
K.
