Maniphest T76863
Entering edit mode on a hidden object causes a crash.
Closed, Duplicate
None
Eugene (cgeugene)
May 18 2020, 5:47 PM
  • BF Blender
Ankit Meel (ankitm)
Eugene (cgeugene)
Julian Mohr (Jules)
Philipp Oeser (lichtwerk)
TheRedWaxPolice (TheRedWaxPolice)
Graphics card: GeForce RTX 2080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.83 (sub 17), branch: master, commit date: 2020-05-15 17:29, hash: rBe5ace51295b9
When the selected (active) object is hidden (H), press Tab and the blender falls.
in the attached file just click tab
  • Create cube
  • select cube
  • hide cube
  • Press Tab
Related Objects
Mentioned Here
rBff144edd8c20: Revert "Cleanup: remove redundant active object NULL check & poll"
Eugene (cgeugene) created this task.May 18 2020, 5:47 PM
Eugene (cgeugene) updated the task description.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.May 18 2020, 6:00 PM
Not sure what that means? You mean it crashes? (I can not reproduce this)
I assume you have tried this with a fresh build from https://builder.blender.org/download/?
I assume you have tried this with File > Defaults > Load Factory Settings?
TheRedWaxPolice (TheRedWaxPolice) added a subscriber: TheRedWaxPolice (TheRedWaxPolice).May 18 2020, 6:10 PM
@Philipp Oeser (lichtwerk) Just tried it... it crashes/close..
Win 10 blender-2.90-c880e54a95dd-windows64
Eugene (cgeugene) added a comment.May 18 2020, 6:14 PM
Yes, I mean crash.
Yes and this is a fresh build just downloaded.
Yes. with File > Defaults > Load Factory Settings,
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Information from Developers.May 18 2020, 6:17 PM
No crash here (still)
Eugene (cgeugene) renamed this task from Entering edit mode on a hidden object causes a drop. to Entering edit mode on a hidden object causes a crash..May 18 2020, 6:19 PM
Julian Mohr (Jules) added a subscriber: Julian Mohr (Jules).May 18 2020, 7:08 PM
@Eugene (cgeugene) or @TheRedWaxPolice (TheRedWaxPolice) can you try a build from today i belive i have seen a similar issue that was fixed in the last three days.
Ankit Meel (ankitm) closed this task as a duplicate of T76837: Blender closing when clicking TAB after I hide object.May 18 2020, 7:58 PM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).
TheRedWaxPolice (TheRedWaxPolice) added a comment.May 18 2020, 9:27 PM
Yeah, it was fixed today rBff144edd8c20645f8064035d7257d637d0ff333e
