Maniphest T76928
FBX exporter doesn't export Constant Interpolation keyframes
Confirmed, NormalKNOWN ISSUE
None
Justin Jensen (neverhood311)
May 21 2020, 12:53 AM
  • Add-ons (BF-Blender)
  • Import/Export
Dalai Felinto (dfelinto)
David Nunes (AlphaEndgame)
Germano Cavalcante (mano-wii)
Petr (Petr)
Philipp Oeser (lichtwerk)
Pratik Borhade (PratikPB2123)
Richard Antalik (ISS)
Operating system: Windows 10 Pro
Graphics card: NVidia Quadro M1200
Broken: 2.82a
The FBX exporter does not export Constant Interpolation keyframes. Instead, they're converted to Linear Interpolation
Open the default scene.
Add a few location keyframes to the cube
Change each keyframe's interpolation type to Constant
Export as FBX
Import into Unity or back into Blender. The keyframes now have Linear Interpolation
Related Objects
Mentioned In
T94855: Key Interpolation bug
T68575: FBX Known issues & TODO's
Mentioned Here
rBA96a51679699c: FBX Exporter: Support special case of constant interpolation
Justin Jensen (neverhood311) created this task.May 21 2020, 12:53 AM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).May 21 2020, 10:53 PM
Could you provide a simple file showing the problem?
Justin Jensen (neverhood311) added a comment.May 22 2020, 5:54 AM
I've attached two files:
The first is a .blend file with an extremely simple animation. I want the cube to jump to the right on frame 20, then back to the origin on frame 40. No interpolation.
The second file is this cube exported to FBX. Upon first inspection, it kind of looks like the keyframes use Constant interpolation, but it's actually just two keyframes on adjacent frames with linear interpolation between them. This is a problem when I bring this 24fps animation into a 60fps application like Unity.
Richard Antalik (ISS) added subscribers: Dalai Felinto (dfelinto), Richard Antalik (ISS).May 25 2020, 1:05 AM
This looks like a limitation of exporting script. By doing some search for this I have found rBA96a51679699c implementing this feature but it has been reverted. I am not familiar with fbx format, so I can't see immediately what the issue was.
It's not clear to me if you wanted to have a go at implementing this. If you do, you can discuss possible solutions on https://devtalk.blender.org or ask @Dalai Felinto (dfelinto) on https://blender.chat/channel/blender-coders
Otherwise we could consider this a known issue or close as accidental feature request.
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Confirmed.Jun 23 2020, 12:09 PM
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "Known Issue".
Philipp Oeser (lichtwerk) edited projects, added Add-ons (BF-Blender), Import/Export; removed BF Blender.
If @Dalai Felinto (dfelinto) was already on it, I'd say we keep as Known Issue.
quoting from the commit message:
I need to tackle this differently.
Bastien Montagne (mont29) mentioned this in T68575: FBX Known issues & TODO's.Jul 28 2020, 11:20 AM
Bastien Montagne (mont29) moved this task from Backlog to Long Term on the Add-ons (BF-Blender) board.
David Nunes (AlphaEndgame) added a subscriber: David Nunes (AlphaEndgame).Oct 15 2020, 4:49 PM
This comment was removed by David Nunes (AlphaEndgame).
Pratik Borhade (PratikPB2123) mentioned this in T94855: Key Interpolation bug.Jan 13 2022, 7:50 AM
Pratik Borhade (PratikPB2123) merged a task: T94855: Key Interpolation bug.
Pratik Borhade (PratikPB2123) added subscribers: Petr (Petr), Pratik Borhade (PratikPB2123).
