Maniphest T76989
Visual glitches when undo after reload multiple images by script (in Material Preview)
Closed, ResolvedKNOWN ISSUE
Bastien Montagne (mont29)
xVanTuring (xVanTuring)
May 23 2020, 12:20 PM
  • BF Blender
  • Pipeline, Assets & I/O
Brecht Van Lommel (brecht)
Clément Foucault (fclem)
Richard Antalik (ISS)
Operating system: Windows 10 1909
Graphics card: Radeon RX 570
Broken: 2.90.0 Alpha, branch: arcpatch-D7884, commit date: 2020-06-15 14:16, hash: rB81fcf23d7cec
Worked: Probably never, 2.82 and earlier will crash, but that may be different bug.
So I'm currently making an add-on to support Substance, it will generate texture based on inputs and save them to disk, it will also generate material and assign texture generated before.
However on Version 2.82a with Material Preview mode after update a property, the add-on generate the texture, and auto reload the images, the press ctrl+z, normally it would undo the property, but it either crashs directly with EXCEPTION_ACCESS_VIOLATION, or ends up with a weird 3d preview. (below it's the normal one)
The weird thing is that it doesn't crash(2.82) if I run blender with blender_debug_log.cmd
  1. Open File
  2. Run script
  3. In 3D viewport side panel click on Toggle option and undo
  4. Repeat until you see glitch in material
Revisions and Commits
rB Blender
Related Objects
Mentioned In
rB5fa6bd8a8ddb: Readfile/Undo: initial refactor of cache preservation code.
T60695: Optimized per-datablock global undo
D8172: Fix missing GPU image free in background mode
xVanTuring (xVanTuring) created this task.May 23 2020, 12:20 PM
xVanTuring (xVanTuring) added a comment.May 23 2020, 12:22 PM
Forget to say, it seems to behavior a little normal on 2.83 beta. it does not crash, but weird preview might occur. (Hope the information is enough)
xVanTuring (xVanTuring) updated the task description.May 23 2020, 12:24 PM
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.May 25 2020, 1:37 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
The description of this report is quite vague.
Can you prepare a simple script in .blend file that you can run and undo that would cause crash? Goal is to minimize time it takes to confirm bug as well as for developer to debug and fix the issue.
xVanTuring (xVanTuring) added a comment.May 25 2020, 10:57 PM
Hey,I made a simple project now. so here I uploaded 2 file, the test.zip contains the test images in 1K reso. After unzip it, you might want to update the image texture node in material, and variable image_dir in script, it just reload the image from disk. After you run the script, simply check to Toggle Option, then redo/undo (just play around), it should crash. I also got a video with 3 times crashing.
Campbell Barton (campbellbarton) changed the task status from Needs Information from User to Needs Information from Developers.Jun 10 2020, 5:04 AM
Richard Antalik (ISS) renamed this task from Blender 2.82a crash randomly when undo after reload multiple images by script (in Material Preview) to Visual glitches when undo after reload multiple images by script (in Material Preview).Jun 15 2020, 9:07 PM
Richard Antalik (ISS) changed the task status from Needs Information from Developers to Confirmed.
Richard Antalik (ISS) updated the task description.
Richard Antalik (ISS) added a project: EEVEE & Viewport.
Clément Foucault (fclem) edited projects, added Pipeline, Assets & I/O; removed EEVEE & Viewport.Jun 30 2020, 7:28 PM
Clément Foucault (fclem) added subscribers: Bastien Montagne (mont29), Clément Foucault (fclem).
Better file with relative paths and textures in one zip.
  • Open file.
  • Run the script in the scripting area.
  • Click multiple time on the new Toggle button in the Viewport sidef panel.
  • Undo until you can see the texture change.
The issue comes from the UNDO system that seems to shuffle the Image Textures. (the data does not correspond to the original data but they seem intact)
This affects GPUTexture but also the imbuf since it affects the UVImage editor (which does not use GPUTextures).
This also comes with a memory leak with GPUTextures not freed. I could not locate where/why this happens.
@Bastien Montagne (mont29) I'll leave it to you.
Clément Foucault (fclem) changed the subtype of this task from "Report" to "Bug".Jun 30 2020, 7:29 PM
Bastien Montagne (mont29) added a comment.Jul 1 2020, 2:40 PM
Cannot really reproduce this, besides a few memleaks that happen once in a while... Will double check how we deal with runtime gputexture thing, but besides that I cannot do much here unless I can reproduce it.
Bastien Montagne (mont29) added a subscriber: Brecht Van Lommel (brecht).Jul 1 2020, 4:22 PM
OK, so spent some more time investigating things and trying to understand what happens, with little success since I cannot even reliably reproduce any issue. But I think we might face one or both of following issues while trying to re-use runtime caches:
  1. race condition.
  2. pointer collisions across undo steps.
Not sure how #1 could happen, since both cache freeing and re-generation on-demand from draw code should happen in main thread, i.e. in a consistent order?
#2 Is also quiet difficult to follow, but since issue happen after repetitive cache freeing (triggered by the reload() RNA code): different caches being re-allocated at the same memory address as another one from a previous undo step.
But before losing more time on that wild goose chase, I'd like to hear from @Brecht Van Lommel (brecht) about that radical solution: since with new undo we re-use fully unchanged datablocks, can't we simply get fully rid of those imamap, movieclipmap, etc. ? Yes, it means that in some cases we'd regenerate the caches when it would not be needed, but I would not expect many changes to image of movieclip IDs to not require a cache reload anyway? And it would seriously simply code in readfile.c. Because right now we end up with some kind of double layer of remapping, makes things really hard to follow...
Bastien Montagne (mont29) moved this task from Backlog to Bugs on the Pipeline, Assets & I/O board.Jul 1 2020, 4:27 PM
Brecht Van Lommel (brecht) added a comment.Jul 1 2020, 4:40 PM
We can't get rid of imamap and similar. This is not only a cache, texture painted images and render results must be preserved.
Bastien Montagne (mont29) changed the subtype of this task from "Bug" to "Known Issue".Jul 1 2020, 5:20 PM
Bastien Montagne (mont29) moved this task from Bugs to Known Issues on the Pipeline, Assets & I/O board.
Then am moving this to known issues, as this is for sure going to be a huge pain to fully understand and fix, and might very well require a complete redesign of how we preserve those caches (as a reminder, we had to add the session uuid thing ti IDs to precisely address that pointer collision issue...).
Bastien Montagne (mont29) mentioned this in T60695: Optimized per-datablock global undo.Jul 1 2020, 5:28 PM
Bastien Montagne (mont29) closed this task as Resolved by committing rB8e0f8bb3e153: New undo cache management: Add Image IDs..Jul 3 2020, 12:57 PM
Bastien Montagne (mont29) mentioned this in rB5fa6bd8a8ddb: Readfile/Undo: initial refactor of cache preservation code..
Bastien Montagne (mont29) added a commit: rB8e0f8bb3e153: New undo cache management: Add Image IDs..
