Maniphest T77237
Tablet - Wacom Tablet Preferences do not work
Closed, Resolved
Nicholas Rishel (nicholas_rishel)
Aryan Dhume (Dustyhunter2050)
May 31 2020, 8:40 PM
  • BF Blender
  • User Interface
  • Wintab High Frequency
Rodrigo de Assis (Vane)
Operating system:Windows 10
Graphics card:NVIDIA GTX 1050 ti
Broken: (2.83)
Worked: (2.82)
All the tablet ExpressKeys and the stylus buttons do not work in the 2.83 version of Blender, but it works totally fine on the previous version.
Just use a Wacom Intuos Pro M tablet and assign a hotkey to an expresskey or to the buttons on the stylus by going to Wacom Tablet Preferences
Aryan Dhume (Dustyhunter2050) created this task.May 31 2020, 8:40 PM
Philipp Oeser (lichtwerk) renamed this task from My Wacom Tablet Preferences do not work to Tablet - Wacom Tablet Preferences do not work .Jun 22 2020, 11:08 AM
Philipp Oeser (lichtwerk) added a project: User Interface.
Rodrigo de Assis (Vane) added a subscriber: Rodrigo de Assis (Vane).Sep 2 2020, 4:29 PM
I have this problem as well.
I'm running Blender version 2.83.5 and all Gizmo related functions (global rotate) and Pam, as well as zoom commands are not working at all.
I have no problems in programs like Krita where my tablet is working as intended, so the problem is Blender related. I had no problems in previous versions of Blender and this is a new issue.
Right click is working as intended. The problem is specific for these we are talking about.
Problem persists in Version 2.9
Nicholas Rishel (nicholas_rishel) added a project: Wintab High Frequency.Oct 21 2020, 6:27 AM
Nicholas Rishel (nicholas_rishel) changed the task status from Needs Triage to Needs Information from User.Oct 31 2020, 2:17 AM
Nicholas Rishel (nicholas_rishel) claimed this task.
Nicholas Rishel (nicholas_rishel) added a subscriber: Nicholas Rishel (nicholas_rishel).
@Aryan Dhume (Dustyhunter2050) @Rodrigo de Assis (Vane) can you test if the issue still exists in Blender 2.92 Alpha?
Rodrigo de Assis (Vane) added a comment.Nov 2 2020, 6:48 PM
@Nicholas Rishel (nicholas_rishel) I solved my problem some time ago. I told everything on this post: https://developer.blender.org/T80387
The problem was that Blender was configured to look for my tablet's commands in Windows INK, so I changed to "Automatic" so it could find my tablet by its own. It worked!
The configuration is located in Edit > Preferences > Input > Tablet, in Tablet API it was settled to Windows INK, changing to Automatic got my tablet working again.
I solved it in Blender 2.83.5, so I can't say if this is a problem present in current versions os Blender.
Nicholas Rishel (nicholas_rishel) added a comment.Nov 2 2020, 8:23 PM
@Rodrigo de Assis (Vane) Could you take a moment to test if you can recreate the issue with Tablet API set to Windows Ink in the build I linked above. A workaround it nice but I'd like to verify whether the original issue is fixed or not.
Rodrigo de Assis (Vane) added a comment.Nov 10 2020, 4:51 PM
@Nicholas Rishel (nicholas_rishel) Alright I'll try it again in the newest version. I'll post here whatever happens in details.
Nicholas Rishel (nicholas_rishel) moved this task from Triage to Backlog on the Wintab High Frequency board.Nov 14 2020, 4:14 AM
Nicholas Rishel (nicholas_rishel) added a comment.Nov 25 2020, 4:52 AM
@Rodrigo de Assis (Vane) pinging once more before I close the issue.
Rodrigo de Assis (Vane) added a comment.Nov 26 2020, 5:34 PM
@Nicholas Rishel (nicholas_rishel) I didn't tested it yet. But don't worry, I'm still going to do it. Just need some more time (things are crazy around here)
Nicholas Rishel (nicholas_rishel) added a comment.Nov 27 2020, 3:36 AM
No worries. If I don't hear back for a couple weeks I'll ping you again but as long as you're replying I'll leave the issue open.
Rodrigo de Assis (Vane) added a comment.Dec 17 2020, 5:52 PM
@Nicholas Rishel (nicholas_rishel) I just testes this matter in Blender 2.90 (as I didn't uploaded it to the newest 2.91) and I changed preferences to WindowsINK and Wintab and in both confiogurations I still managed to use navigation through my Wacom tablet perfectly. Do you need any specific data, I can provide?
Also sorry for the late reply, I'm not using Blender in a while now becouse I'm focusing in another software.
Nicholas Rishel (nicholas_rishel) closed this task as Resolved.Dec 17 2020, 7:55 PM
Checking in the alpha would be ideal, but if things are working for you in 2.90 I suspect your problem is no longer present. I'll go ahead and mark this as resolved for now.
Nicholas Rishel (nicholas_rishel) moved this task from Backlog to Fix assumed on the Wintab High Frequency board.Dec 18 2020, 2:24 AM
