Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 445.87
Broken: version: 2.90.0 Alpha, branch: master, commit date: 2020-05-31 21:28, hash: rBfcccee0c3372
Addon Information
Name: FBX format (4, 21, 2)
Author: Campbell Barton, Bastien Montagne, Jens Restemeier
Fails to export .fbx animation/NLA in this particular situation. cause unknown
Successfully retarget a .BVH to existing armature. Watch as the retarget makes an NLA strip instead of keyframes. Press play, watch the animation work successfully. Try to export as .FBX, see following error messages
FBX export prepare: Wrapping Animations...
File "K:\Programs\blender-2.90.0x64\2.90\scripts\addons\io_scene_fbx\__init__.py", line 636, in execute
return export_fbx_bin.save(self, context, **keywords)
File "K:\Programs\blender-2.90.0x64\2.90\scripts\addons\io_scene_fbx\export_fbx_bin.py", line 3198, in save
ret = save_single(operator, context.scene, depsgraph, filepath, **kwargs_mod)
File "K:\Programs\blender-2.90.0x64\2.90\scripts\addons\io_scene_fbx\export_fbx_bin.py", line 3079, in save_single
scene_data = fbx_data_from_scene(scene, depsgraph, settings)
File "K:\Programs\blender-2.90.0x64\2.90\scripts\addons\io_scene_fbx\export_fbx_bin.py", line 2458, in fbx_data_from_scene
animations, animated, frame_start, frame_end = fbx_animations(tmp_scdata)
File "K:\Programs\blender-2.90.0x64\2.90\scripts\addons\io_scene_fbx\export_fbx_bin.py", line 2093, in fbx_animations
ob.animation_data.action = None
AttributeError: bpy_struct: attribute "action" from "AnimData" is read-onlyOn further research, it is probably the same as the following
I have the same problem but and google it and got here, in my case I had renamed an Action and there was an action assigned to the mesh with this name and there were an action with the same name assigned to the armature. It has to be assigned to just one, even though I think it should always be assigned to the armature. On the outliner you can unlink the actions, it solved my problem. I hope this can be usefull to you.
