Maniphest T77985
Creating new texture slot of particle systems by python will corrupt texture's influence on particles.
Closed, Duplicate
None
Borek Bures (spiv)
Jun 18 2020, 4:21 AM
  • BF Blender
Borek Bures (spiv)
Philipp Oeser (lichtwerk)
Operating system: Win
Graphics card:
Broken: 2.83.0 LTS (2.90.0 Alpha Hash: b89898cbd381)
Worked: never
  1. open TextureSlot_Bug.blend
  2. run script: SetTextureSlot_bug.py
  3. select Plane object and execute operator: setparticlestextureslot
    • script will create new particles texture slot
    • appends black/white texture to the created slot
    • sets influence of density
  4. then particles should be masked only on half of plane, but they are not - slot is corrupted
Workaround - bug proof
  1. reopen TextureSlot_Bug.blend
  2. select Plane object particles and create new empty texture on first Texture slot
  3. remove this texture - this step will create new empty slot
  4. run script: SetTextureSlot_bug.py and execute operator: setparticlestextureslot
  5. the particles are masked - everything works properly because script doesn't have to create a new texture slot
Borek Bures (spiv) created this task.Jun 18 2020, 4:21 AM
Borek Bures (spiv) updated the task description.Jun 19 2020, 10:46 AM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Jun 22 2020, 10:53 AM
This is due to the texture slot being created with 'MIX' blend_type from the API by default (whereas if you do the same from the interface, it is created with 'MULTIPLY')
So workaround is to set the
mtex.blend_type = 'MULTIPLY'
in your script, see:
This has been reported before, see T76951: Particle system texture added via API not working ['blend_type' when created using the interface is MULTIPLY, whereas when created through API, its value is MIX], will merge these reports...
