Maniphest T78294
Cycles Alpha (mask) broken
Closed, Archived
Brecht Van Lommel (brecht)
Eugene Du (APEC)
Jun 26 2020, 9:20 AM
  • BF Blender
Andrew Walsh (andywalshart)
Eugene Du (APEC)
Rahul Chaudhary (RC12)
Graphics card: GeForce GTX 1650 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.83.0, branch: master, commit date: 2020-06-03 14:38, hash: rB211b6c29f771
Material with Alpha transparency incorrect display in Cycles
Eevee
Eugene Du (APEC) created this task.Jun 26 2020, 9:20 AM
Rahul Chaudhary (RC12) added a subscriber: Rahul Chaudhary (RC12).Jun 26 2020, 11:49 AM
This is not a bug, you have to increase the transparency light bounces for it to work correctly
Eugene Du (APEC) added a comment.Jun 26 2020, 11:52 AM
If I have more faces density I need to increase bounces, so how I need to calculate this?
Investigation here
https://blenderartists.org/t/need-help-with-mask-in-cycle/1237174
Brecht Van Lommel (brecht) closed this task as Archived.Jun 26 2020, 11:58 AM
Brecht Van Lommel (brecht) added a subscriber: Brecht Van Lommel (brecht).
Indeed this is not a bug.
Eugene Du (APEC) added a comment.EditedJun 26 2020, 12:05 PM
So Eevee calculate this in a seconds, and cycles need to increase bounces to the ridiculous numbers and don't even get result similar to eevee?
nice!
How to get shadows with this huge numbers for bounce?
Eugene Du (APEC) added a comment.EditedJun 26 2020, 12:23 PM
Modo example with only 1 bounce for all lights
Blender with 70 bounces
Modo with 1 bounce
Brecht Van Lommel (brecht) added a comment.Jun 26 2020, 12:31 PM
This bug tracker is not for user support.
You simply need more transparent bounces in this case, while other bounces can be as low as you want. The same amount of transparent bounces will be needed in any renderer, they just might not have a setting to control the maximum and have transparent bounces set to infinite.
Evan Wilson (EAW) added a subscriber: Andrew Walsh (andywalshart).
