Maniphest T78522
Image Goes Black After Denoise
Closed, Duplicate
None
Aran Thomas (GodSpeed)
Jul 2 2020, 7:32 AM
  • BF Blender
Rahul Chaudhary (RC12)
Sharath (sharaths21312)
Operating system: Windows 10 - 10.0 , build - 18362
Graphics card: AMD Radeon R2 Graphics
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
It Appears Black When i Connect to the Denoise Node. My cpu has SSE 4.1 or greater.
I connect the new Denoise Node in the composer and the Render appears in Black
Aran Thomas (GodSpeed) created this task.Jul 2 2020, 7:32 AM
Sharath (sharaths21312) added a subscriber: Sharath (sharaths21312).EditedJul 2 2020, 9:06 AM
Are you sure you plugged it in correctly and gave the denoising data? Here is a video of it:
It also works only in cycles. While rendering in EEVEE, disconnect your denoise node as EEVEE doesn't use it.
Here is the result:
Sharath (sharaths21312) changed the task status from Needs Triage to Needs Information from User.Jul 2 2020, 9:37 AM
Aran Thomas (GodSpeed) added a comment.EditedJul 2 2020, 10:08 AM
Yep all the nodes are connected properly.
Aran Thomas (GodSpeed) added a comment.EditedJul 2 2020, 10:27 AM
My CPU also has SSE4.1 +. I also tried Using denoiser after rendering with CPU and GPU separately, but nothing seems to work
Aran Thomas (GodSpeed) changed the task status from Needs Information from User to Needs Triage.Jul 2 2020, 10:38 AM
Rahul Chaudhary (RC12) added a subscriber: Rahul Chaudhary (RC12).EditedJul 2 2020, 10:55 AM
Try updating to latest blender version 2.83.1 LTS, and see if the issue is still there
https://www.blender.org/download/
or try it on the latest experimental build https://builder.blender.org/download/
Aran Thomas (GodSpeed) added a comment.Jul 2 2020, 11:16 AM
I tried it all but no use. I even Reinstalled it a couple of times :(
