Maniphest T79432
Boolean modifier difference adds instead of subtracting
Closed, Duplicate
None
Eagle Gamma (eaglegamma)
Jul 31 2020, 7:16 PM
  • BF Blender
Richard Antalik (ISS)
Graphics card: AMD Radeon(TM) R3 Graphics ATI Technologies Inc. 4.5.13558 Core Profile Context 26.20.11008.1007
Broken: version: 2.83.2, branch: master, commit date: 2020-07-09 05:50, hash: rB239fbf7d936f
Worked: has not worked in any previous version tried
The boolean modifier with a difference operation in some cases adds the meshes instead of subtracting them.
This problem may occur in part because of a mirroring of some vertices in the mesh on which the modifier is added.
I have seen this problem in numerous versions of Blender (2.83.2, 2.79b, 2.76b), running on numerous different systems.
Here is a StackExchange issue I made a while ago (with screenshots). I had thought that a different solver resolved the issue, but it still persists even in more recent versions.
https://blender.stackexchange.com/questions/160711/why-does-boolean-difference-add-material-to-this-mesh
I have tried editing the meshes involved, using different modifiers, and other approaches. So far, I have not managed to find a way to fix or work around this issue.
In the attached file, the mesh "Cylinder.001.Frame" has two active meshes that should show difference modifiers. The one with the mesh "Text.Version.002.3-4mm.goggles1.001" adds material instead of subtracting it.
Eagle Gamma (eaglegamma) created this task.Jul 31 2020, 7:16 PM
Eagle Gamma (eaglegamma) added a comment.Jul 31 2020, 10:02 PM
It looks like the mirroring is irrelevant. The same issue appears even on duplicated but non-mirrored vertices.
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).Aug 2 2020, 1:34 AM
This is duplicate of T68144, will merge but please check if issue exists before reporting. Also in future, upload simplified .blend file - in this there is a lot of unnecessary objects.
Richard Antalik (ISS) closed this task as a duplicate of T68144: Boolean Difference works like Boolean Union - modifier bug.Aug 2 2020, 1:34 AM
