Maniphest T80046
Interface: Copy Attributes Menu not activating
Closed, Archived
None
S. Frady (fotosonics)
Aug 23 2020, 4:20 PM
  • Add-ons (Community)
Omar Emara (OmarSquircleArt)
Yevgeny Makarov (jenkm)
Operating system: Darwin-17.7.0-x86_64-i386-64bit 64 Bits
Graphics card: ATI Radeon HD 5750 OpenGL Engine ATI Technologies Inc. 4.1 ATI-1.68.25
Broken: version: 2.83.5, branch: master, commit date: 2020-08-19 06:07, hash: rBc2b144df395f
Addon Information
Name: Copy Attributes Menu (0, 4, 9)
Author: Bassam Kurdali, Fabian Fricke, Adam Wiseman
After selecting two objects, and hitting CTRL-C, copy options do not appear.
Select two objects. Hit CTRL-C. Copy options do not appear.
S. Frady (fotosonics) created this task.Aug 23 2020, 4:20 PM
Yevgeny Makarov (jenkm) added a subscriber: Yevgeny Makarov (jenkm).Aug 23 2020, 5:30 PM
I can't reproduce it with 2.83.5 and 2.91.0 on macOS.
Maybe you press Cmd instead of Ctrl?
S. Frady (fotosonics) added a comment.Aug 23 2020, 6:51 PM
Negative. I also used this before but for some reason it's not working now.
Yevgeny Makarov (jenkm) added a comment.Aug 23 2020, 8:05 PM
Try also "Load Factory Settings", activate only this add-on and see if it works.
S. Frady (fotosonics) added a comment.Aug 24 2020, 4:11 PM
This is not working at all.
S. Frady (fotosonics) added a comment.Aug 24 2020, 4:12 PM
Going to try some other ways. Thanks
Omar Emara (OmarSquircleArt) changed the task status from Needs Triage to Needs Information from User.Mar 10 2022, 11:50 AM
Omar Emara (OmarSquircleArt) added a subscriber: Omar Emara (OmarSquircleArt).
Can you check if the operation is correctly mapped to that key binding in the user preferences? Can you also check if this still happens in the latest version of Blender? https://builder.blender.org/
Omar Emara (OmarSquircleArt) added a comment.Apr 5 2022, 10:55 AM
Just a poke regarding my inquiry above, otherwise, we will have to archive this for now.
Omar Emara (OmarSquircleArt) closed this task as Archived.May 24 2022, 12:53 PM
