Maniphest T80059
My PC crashes when I try to render in cycles
Closed, Duplicate
Robert Guetzkow (rjg)
Jáchym (AMEXif)
Aug 23 2020, 10:53 PM
  • BF Blender (2.82)
Ankit Meel (ankitm)
Jáchym (AMEXif)
System Information:
Operating system: windows 10
Graphics card: AMD RX 560 4GB
Blender Version:
Broken: every version of blender.
Worked: none
Short description of error:
Basically when I render with cycles on a GPU after a random period of time rendering my screen either flashes white and then my PC crashes, or dots show up all over my screen as if my GPU was failing. Both resulting in a complete crash of the system.
Exact steps for others to reproduce the error:
It's random, but happens 85% of the renders I try to make.
Jáchym (AMEXif) created this task.Aug 23 2020, 10:53 PM
Robert Guetzkow (rjg) removed Jáchym (AMEXif) as the assignee of this task.Aug 23 2020, 10:57 PM
Robert Guetzkow (rjg) added a subscriber: Robert Guetzkow (rjg).EditedAug 23 2020, 11:02 PM
If your operating system crashes, then the cause is likely one of the following:
  • Bug in the graphics driver
  • Overheating
  • PSU doesn't provide enough power
  • Issue with the operating system
  • Hardware failure
Blender itself cannot crash the entire system without a fault somewhere else. I would suggest that you update your graphics driver first and check if that solves the issue.
Please also open Blender, save your system information through Help > Save System Info and upload the file by clicking on the upload button, as shown in the screenshot below, or via drag-and-drop.
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.Aug 23 2020, 11:02 PM
Jáchym (AMEXif) added a comment.Aug 23 2020, 11:57 PM
  1. I tried reverting the GPU drivers and still nothing helps.
  1. Overheating is not an option because my GPU/CPU hardly goes above 65C.
  1. I tried unlocking the power output to 600W and no change.
  1. Might be.
  1. Not the case as I put the PC through test at my local IT-store and all is fine.
I think I'll just wait for updates on my drivers/windows for a fix. Thanks for your time.
Robert Guetzkow (rjg) closed this task as Archived.Aug 31 2020, 12:02 PM
Robert Guetzkow (rjg) claimed this task.
Thank you for your report. I'll be closing the ticket then.
