Maniphest T80074
Dope Sheet: Only Show Selected and Show Hidden don't work together when Disable in Viewport is animated
Closed, Duplicate
None
Alex (SpectreFirst)
Aug 24 2020, 12:52 PM
  • BF Blender
Alex (SpectreFirst)
Philipp Oeser (lichtwerk)
Intel Core 2 Quad, 8 Gb RAM, NVidia GeForce GTX 960 2GB
Windows 7 x64
Broken: 2.8x, 2.9x
Worked: 2.79
Dope Sheet's Only Show Selected and Show Hidden options stopped working since 2.79 when Disable in Viewport property is animated – when you move the slider to position when Disable in Viewport is disabled (and object is hidden) it seems to automatically deselect the object which makes all its keyframes disappear from the Dope Sheet.
  1. Open provided file in 2.79 and move the animation slider to the first frame, you will notice that keyframes are visible in Dope Sheet regardless of Visibility state.
  2. Open provided file in 2.8 or 2.9 and do the same – when you will move the slider to the first frame, keyframes will disappear.
Alex (SpectreFirst) created this task.Aug 24 2020, 12:52 PM
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Aug 24 2020, 1:03 PM
This has been reported before, see T68313: Dopesheet Display Hidden doesn't work property combined with Only Selected., will merge these reports.
