Operating system: Linux-4.15.0-112-generic-x86_64-with-debian-buster-sid 64 Bits
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 450.57
Broken: version: 2.83.5, branch: master, commit date: 2020-08-19 06:07, hash: rBc2b144df395f
also tried in 2.91 alpha same result
Worked: /
Mesh with active shape keys and multires is beenig sculpted upon and pressed undo. This after leaving sculpt mode corrupts mesh by duplicating Shape Keys effect. The only solution I have found is reloading file.
attached a prepared file with a simple mesh with two active shape keys and multires.
These steps assume using this attached file:
-open attached file
-select object "cube"
-change to sculpt mode
-drag a line on the mesh with active brush
-undo sculpt change
-switch back to object mode
-as you can see the effect of key shapes has been doubled
attached blender file
Adding before and after images for comparison
before undo
after undo
