Maniphest T80425
Volumetrics not working in 2.9 eevee
Closed, Duplicate
None
Raghav Anil Kumar (Blenderag)
Sep 3 2020, 10:56 AM
  • BF Blender
Operating system: win10
Graphics card: Titan rtx
Broken: (example: 2.90.0, edbf15d3c044, master, 2020-09-03, as found on the splash screen)
Worked: works in 2.83.5
Volumetrics through Principled volume material aren't appearing in Eevee.
Head to shader editor and switch the mode to world. Add principled volume material and plug it into world output. This should normally render volumetrics i.e fog etc, but it stays the same. Plesae refer the attached image to see the problem .
Thank you
Raghav Anil Kumar (Blenderag) created this task.Sep 3 2020, 10:56 AM
Alaska (Alaska) closed this task as a duplicate of T80332: Principle Volume in World Shader is not working.Sep 3 2020, 10:59 AM
