Maniphest T80455
Modifier re-evaluation makes editing dimensions unreliable
Closed, ArchivedTO DO
Sep 4 2020, 7:30 AM
  • Papercut
  • Modeling
Currently editing dimensions uses the bounding box that's recalculated while dragging.
This can cause a feed-back loop as the objects scale is used by some modifiers which calculate a new bounding based on the scale which is then used in dimensions.
In the case of armature modifier - any zero scaled axis makes causes the mesh to scale into a single point, making any further changes to the dimensions not have any effect. See T67442.
Campbell Barton (campbellbarton) changed the task status from Needs Triage to Confirmed.Sep 4 2020, 7:30 AM
Campbell Barton (campbellbarton) triaged this task as Low priority.
Campbell Barton (campbellbarton) created this task.
Campbell Barton (campbellbarton) updated the task description.
Campbell Barton (campbellbarton) added a project: Modeling.
Campbell Barton (campbellbarton) changed the subtype of this task from "Report" to "To Do".Sep 4 2020, 7:57 AM
Closing this, will keep T67442 open.
Campbell Barton (campbellbarton) closed this task as Archived.Sep 4 2020, 7:57 AM
Campbell Barton (campbellbarton) claimed this task.
