Maniphest T80537
Particle source face creates an unwanted object in the middle of mesh
Closed, Duplicate
None
Daegon Kim (dk123)
Sep 6 2020, 9:30 PM
  • BF Blender
Ankit Meel (ankitm)
Daegon Kim (dk123)
Germano Cavalcante (mano-wii)
Richard Antalik (ISS)
Operating system: Windows 10
Graphics card:
Broken: 2.9
Worked:
Creating a particle system with source as faces, creates an unwanted particle in the middle of the mesh.
Create a mesh (cube)
Create a particle (cube).
Create a particle system on the mesh with source as cube, and emitting from faces.
https://drive.google.com/file/d/1fTqEKrQ1nDVLWIlQ7gPvCa8oHkM4_TIA/view?usp=sharing
Related Objects
Mentioned In
T80739: Particle Created at Object's Origin Even If No Face Is There
Mentioned Here
rB6e7617211b67: UI messages fixes...
Daegon Kim (dk123) created this task.Sep 6 2020, 9:30 PM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Sep 9 2020, 8:09 PM
This is often a limitation when you add modifiers after the particle.
But in the attached file I don't see this particle in the middle of the object.
Did I get the problem wrong?
Daegon Kim (dk123) added a comment.Sep 9 2020, 11:42 PM
You've understood the problem correctly - I'm using the same blend file, but I get this:
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Sep 10 2020, 6:55 AM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
I also can't reproduce this issue.
Please download development build from https://builder.blender.org/download/ and check if this is still issue.
Try to update GPU drivers.
Click on Help > Report a Bug and copy system information to this report so we can know what GPU and driver you are using.
Daegon Kim (dk123) added a comment.Sep 12 2020, 2:25 AM
I can confirm this still persists in the daily build. Info:
Graphics card: GeForce GTX 1060 3GB/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 443.18
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-11 09:14, hash: rB1b6dd42803df
Richard Antalik (ISS) added a comment.Sep 14 2020, 2:00 PM
Latest driver should be 452.06 so please check if that solves the issue
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).Oct 7 2020, 1:03 PM
Cannot redo on Intel HD 6000, macOS 10.14, Blender version rB6e7617211b67: UI messages fixes....
No cube at the origin.
