Maniphest T80544
Can't change font text on VSE
Closed, ArchivedBUG
None
Michael Molina (Drakem)
Sep 7 2020, 2:34 AM
  • BF Blender
  • VFX & Video
Clint Hobson (Domarius)
Evan Wilson (EAW)
François-Olivier Devaux (fodevaux)
Germano Cavalcante (mano-wii)
Michael Jastram (jastram)
Peter Fog (tintwotin)
Richard Antalik (ISS)
Graphics card: GeForce GTX 1050 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.06
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: rB0330d1af29c0
Once I save the file it does not allow me to change the text font of the text-strip and uses the default font instead.
Important: the "video editing" startup template I use it maybe since 2.81 and work's fine with another template
Open the file
Save the file (maybe the bug can work without saving sometimes)
Add text
Increase the size (I think this step doesn't matter)
Try change the font.
Michael Molina (Drakem) created this task.Sep 7 2020, 2:34 AM
Germano Cavalcante (mano-wii) changed the task status from Needs Triage to Confirmed.Sep 9 2020, 8:20 PM
Germano Cavalcante (mano-wii) added a project: VFX & Video.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).
In fact with the file attached the font does not change.
I'm not sure if this is a VFX & Video or a Pipeline, Assets & I/O problem.
But I can confirm the bug
Clint Hobson (Domarius) added a subscriber: Clint Hobson (Domarius).Sep 21 2020, 1:10 AM
Michael Jastram (jastram) added a subscriber: Michael Jastram (jastram).Sep 28 2020, 12:23 PM
Not sure whether it's the same issue, but I found a workaround that may help debug this:
https://blender.stackexchange.com/a/195973/35799
Evan Wilson (EAW) added a subscriber: Evan Wilson (EAW).EditedSep 28 2020, 1:56 PM
I observed this behavior on Linux with Blender 2.83.5.
I found a workaround:
  1. Create a font strip in VSE
  2. Set the font you would like to use (the preview does not reflect this)
  3. Delete the strip
  4. Perform an undo. At least in my configuration, the text is rendered in the correct font.
It is better UX to copy and paste it here. 😉 Thank you for the additional information. 🤗
Michael Molina (Drakem) added a comment.Sep 28 2020, 4:19 PM
    Delete the strip
Works
Clint Hobson (Domarius) added a comment.Oct 4 2020, 9:44 PM
Worth mentioning it's not just when adding a new text strip - when you open an existing project, all text is immediately rendered with the default font, so it's a show stopper on your project. I thought the project file was broken somehow but when I downgraded to 2.8 LTS, the same project file opens with all the text correct. (Yep, I shouldn't be using the latest version of software on a long term project, but that's what you get when installing software from Add/Remove Programs in Manjaro)
Sergey Sharybin (sergey) moved this task from Backlog to Bugs on the VFX & Video board.Oct 28 2020, 12:43 PM
Peter Fog (tintwotin) added a subscriber: Peter Fog (tintwotin).EditedDec 27 2020, 11:32 AM
Still broken in 2.92 and needs a Video Sequencer tag(why I can't add tags?).
Also Copy to Selected doesn't work for fonts, which is quite crippling, since users a likely to want all text strips in the same font for ex. subtitles. +Alt doesn't work either.
François-Olivier Devaux (fodevaux) added a subscriber: François-Olivier Devaux (fodevaux).Feb 10 2021, 9:27 PM
Richard Antalik (ISS) closed this task as Archived.Nov 15 2022, 9:45 PM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
Checking reports without VSE tag, this seems to be resolved, so will close.
