Graphics card: GeForce GTX 1080/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 441.87
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-07 08:12, hash: rBb351607996e4
Worked: Some time before binary diffing was implemented maybe?
Note: This is about text editor operators, nothing to do with Text objects in the viewport.
Custom text operators that modify the text (text.body, text.write(), etc.) are missing undo steps IFF an object is in edit mode.
When an object is in object mode, however, the undo works as expected.
Text operators implemented in C work fine. Assuming the solution is letting custom operators push or tag undo like internal ones.
- Load the example blend. The cube will be in edit mode.
- Run script. A new button "Modify Body" is placed in the header of Text Editor.
- Click the button a few times.
- Try to undo (doesn't work)
- Toggle to Object mode and do steps 3 and 4 again (undo works)
