Maniphest T80622
Move to trash / OK button that again
Closed, Resolved
Richard Antalik (ISS)
Kent Davis (mac4kent)
Sep 9 2020, 11:54 AM
  • BF Blender
  • Platform: macOS
  • Platforms, Builds, Tests & Devices
Ankit Meel (ankitm)
Brecht Van Lommel (brecht)
Garry R. Osgood (grosgood)
Raimund Klink (Raimund58)
Sergey Sharybin (sergey)
Operating system: Darwin-20.1.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 575 OpenGL Engine ATI Technologies Inc. 4.1 ATI-4.0.36
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-07 22:02, hash: rB5c2ac8520e07
That again same as before they did remove code cause Mac appear (Move to TRASH) / (OK) button. Please put back is the same code make sure to appear Open, Cancel. I am show you is the same as before and September 7, and 8, 2020
Related Objects
Kent Davis (mac4kent) created this task.Sep 9 2020, 11:54 AM
Garry R. Osgood (grosgood) changed the task status from Needs Triage to Needs Information from User.Sep 9 2020, 1:48 PM
Garry R. Osgood (grosgood) added a subscriber: Garry R. Osgood (grosgood).
@Kent Davis (mac4kent)
From the error message: '"Blender App" cannot be opened because the developer cannot be verified' suggests that the downloaded blender executable has not been signed, a security verification step. I do not know if the extra chore of signing MacOS install images is taken by the blender team for daily test builds. Assuming that daily test builds are unsigned and not verifiable, have you performed any steps to relax security on your own machine, such as suggested here, for the purpose of running blender test builds?
  1. Cannot open file because identity of developer cannot be verified (Source: Apple Communities)
  2. Allowing Third Party Applications to Install on a MacBook (Source: Northern Michigan University)
These steps do compromise security. If you do not choose to do that, then can you achieve your ends with the official releases?
Thank you!
Kent Davis (mac4kent) added a comment.Sep 9 2020, 2:36 PM
@Garry R. Osgood (grosgood) that is not true. They did fix code make it work that happen before. Blender 2.91 need to fix code.
Blender 2.91 Alpha of September 5, 2020 it work, 6 it work, 7 that happen cause. 8 that happen cause. need to fix.
Robert Guetzkow (rjg) added projects: Platform: macOS, Platforms, Builds, Tests & Devices.Sep 9 2020, 4:44 PM
Garry R. Osgood (grosgood) added a comment.Sep 10 2020, 12:52 AM
That theory can be dismissed.
  • T66998, a task to sign macOS daily builds. Addressed by Sergey Sharybin in rB3125cfceec35ef14374ae98f9a400e7a678287a2 Mon Feb 3 17:03:51 2020 +0100.
Nonetheless, it is a matter of fact that the Gatekeeper on your platfom is deciding that your blender binary is unsigned and unnotarized. (and would like you to put it in the trash can). I doubt that there has been a general failure in Blender buildbot's signing method, otherwise, at this time, there would be a deluge of similar reports on the tracker. That has not been the case.
However, I understand you are beta-testing macOS 11. I also gather that code signing for large projects such as Blender has its subtle aspects, in particular, the signing order of dependent modules matters, per unofficial documentation furnished by "Quinn the Eskimo", a support person for Apple developers ( Signing a Mac Product For Distribution ). While it is an untested theory for now, it isn't hard to imagine that the Gatekeeper for beta 11 is more stringent than the Gatekeeper for the current macOS release, which beta testers such as yourself would uncover. It would be very useful at this point if other testers of macOS 11 beta could download a post-September 7 macOS build of Blender and confirm the error message you have here.
Are you familiar with a task number describing such a fix? It would be very useful to cite that here. Thank you.
Kent Davis (mac4kent) added a comment.Sep 10 2020, 2:58 AM
Update MacOS 11 beta last Sept 3, 2020 there is nothing wrong.
Blender 2.91 happen last September 7 not MacOS 11.
Kent Davis (mac4kent) added a comment.Sep 10 2020, 4:05 AM
Blender 2.91 Alpha September 9, 2020 = It work, Now you see.
I knew it Blender does not MacOS 11.
Just wait to see Sept 10, 11, 12, 13, 14 if happen again then I will send again. Same as before 2.8x
2.8 was it work later 2.8x (you see "x" that mean other number happen and I send and they did fixed finally it work until again recent Sept 7, 8 same thing of Blender 2.91. Now September 9 it work. Just wait to see if again.
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).Sep 10 2020, 6:45 AM
Ankit Meel (ankitm) added a subscriber: Brecht Van Lommel (brecht).Sep 10 2020, 6:50 AM
@Brecht Van Lommel (brecht) the macOS master bot has been skipping (or at least the UI says so) code signing since build 726.
Brecht Van Lommel (brecht) added a comment.Sep 10 2020, 11:25 AM
@Ankit Meel (ankitm), that's just the builds for every commit which are also not uploaded, the nightly builds still do code signing.
Brecht Van Lommel (brecht) added a subscriber: Sergey Sharybin (sergey).EditedSep 10 2020, 12:14 PM
@Sergey Sharybin (sergey) maybe signing and notarization is randomly failing.
Are there any logs where we can see for that? The buildbot logs by themselves don't seem to have anything, since this happens on another server.
Garry R. Osgood (grosgood) changed the task status from Needs Information from User to Needs Information from Developers.Sep 10 2020, 1:14 PM
@Kent Davis (mac4kent):
Thank you very much.
If I understand:
  1. a spate of such errors as you report in and around when Task 66998 was under way, ceasing around February 2020, when this task was resolved and daily macOS builds commenced being signed.
  2. most recently the macOS builds for September 7th and September 8th failed your Gatekeeper, which complained that the Blender 2.91 binaries were unsigned and unnotarized.
  3. however, the macOS binary for September 9th succeeded. We will see what the near future brings to us.
Links to logs from Blender Buildbot infrastructure certainly report a spate of macOS builds failing in the test scripts, but I did not delve into them too deeply, nor did I attempt to associate successful build numbers with images available to download on September 7 or 8. I would think that if an unsigned .dmg image actually got posted to downloads there would be a spike of reports such as these. That's why I'm inclined to think that gatekeeping on the beta macOS is sensitive to issues that the current macOS gatekeeper is lenient about. That is my shiny, untested theory of the moment and I adore it; I haven't yet subjected it to anything so rude as facts.
I think it prudent to keep this open for awhile as a collection point.
Ankit Meel (ankitm) added a comment.EditedSep 10 2020, 1:33 PM
Yes beta macOS is unstable sure, but two reports from Catalina were there back in May about 2.83 and 2.90 T76749 which were fixed by a re-download.
Hopefully this gets fixed similarly: "Just wait to see Sept 10, 11, 12, 13, 14 if happen again then I will send again."
It will also be good to make sure that signed bundles are uploaded and it's always a corrupt download that causes the issue.
Raimund Klink (Raimund58) added a subscriber: Raimund Klink (Raimund58).Sep 10 2020, 4:15 PM
Kent Davis (mac4kent) added a comment.Sep 10 2020, 4:21 PM
@Garry R. Osgood (grosgood) , I really HATE GateKeeper.app I never really NEVER install Gatekeeper. They did really wants damage everyone Mac on Gatekeeper. I kick GateKeeper.app out.
@Ankit Meel (ankitm) Yes correct answer this about 10, 11, 12, 13, 14 and you do good remember last May are correct you answer.
Sergey Sharybin (sergey) added a comment.Sep 11 2020, 10:01 AM
@Brecht Van Lommel (brecht), the notarization server itself gives misleading information. The latest issue with notarization I've looked into was caused by an unfortunate chain of events:
  • Linking Blender executable got aborted, leaving temp linker file in place
  • It got copied to the install directory
  • Codesign was fine with it, but notarization did not like it at all
There was always a TODO in the list of the CI process to add checks and logs related on codesign, but is something I hoped devops will help us with. If you think this is becoming urgent to fix now I do it. Otherwise I would wait for James.
Sergey Sharybin (sergey) added a comment.Sep 11 2020, 2:56 PM
@Brecht Van Lommel (brecht), started the codesign_error_tracker branch. It will take some more time to make sure macos/windows are properly handled, and to deploy to the production.
There is more things we can do on top of that, solving little glirks of the install target and things like that.
Kent Davis (mac4kent) added a comment.Sep 15 2020, 6:19 AM
I check everything good work.
Blender 2.91 Alpha date:
September 2020
5 Pass
6 Pass
7 Fail
8 Fail
9 Don't remember
10 Pass
11 Pass
12 Pass
13 Pass
14 Pass
All done
Richard Antalik (ISS) closed this task as Resolved.Sep 15 2020, 11:42 AM
Richard Antalik (ISS) claimed this task.
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
Thanks for info, closing.
Kent Davis (mac4kent) added a comment.Sep 15 2020, 12:59 PM
Sure you are welcome.
