Maniphest T80744
Absolute Grid Snap doesn't work in object/Edit mode when using Axis locking
Closed, Duplicate
None
Tomi (Tvartiainen)
Sep 13 2020, 3:12 PM
  • BF Blender
Andrii Mykhailov (zelfit)
Germano Cavalcante (mano-wii)
Tomi (Tvartiainen)
Graphics card: GeForce GTX 1070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 446.14
Broken: version: 2.91.0 Alpha, branch: master, commit date: 2020-09-11 09:14, hash: rB1b6dd42803df
Worked: 2.90.0
Absolute Grid Snapping not working when moving objects with Axis locking (X, Y, Z) in object/edit mode.
  1. Open Blender with factory settings
  2. Enable snapping.
  3. Set Snapping to increment and check Absolute Grid Snap option.
  4. Move the default cube with Axis locking (X, Y, Z) in object/edit mode (in edit mode select whole object or part of it, doesn't matter)
  5. Snapping doesn't do anything.
Related Objects
Mentioned Here
T80677: Absolute grid snapping doesn't work with the move tool axes.
rB77f6d9dbc999: Fix missing return value in fix for T80677
Tomi (Tvartiainen) created this task.Sep 13 2020, 3:12 PM
Tomi (Tvartiainen) renamed this task from Absolute Grid Snap doesn't work in object mode when using Axis locking to Absolute Grid Snap doesn't work in object/Edit mode when using Axis locking.Sep 13 2020, 6:38 PM
Tomi (Tvartiainen) updated the task description.
Andrii Mykhailov (zelfit) added a subscriber: Andrii Mykhailov (zelfit).Sep 14 2020, 1:10 AM
Same for me. Worked fine in 2.9
Tomi (Tvartiainen) added a comment.Sep 14 2020, 2:43 AM
Just noticed that this should already have been fixed with patch 77f6d9dbc999.
Sorry about this duplicate report, I did not notice that the build I downloaded today from blender.org was that old (build in 11.9).
Also despite searching for this particular problem, I failed to notice that this bug was already reported in T80677.
I tried Absolute snapping with fresh build and it worked as intended.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Sep 15 2020, 7:57 PM
Yes, this has already been fixed
Germano Cavalcante (mano-wii) closed this task as a duplicate of T80677: Absolute grid snapping doesn't work with the move tool axes..Sep 15 2020, 7:57 PM
