Maniphest T80780
Blender 2.9 external renderer shader node bug
Closed, Archived
Richard Antalik (ISS)
Nandeya charles (sharlybg)
Sep 14 2020, 6:45 PM
  • BF Blender
  • Nodes & Physics
Ankit Meel (ankitm)
Juan Gea (juang3d)
Simon Wendsche (BYOB)
Tokens
"Love" token, awarded by juang3d.
Operating system: windows 10 64 bit
Graphics card: RTX 2060 super
Broken: Blender 2.90 official / but it happen since a while now with older blender version
Worked: reported once here : https://developer.blender.org/T76381
Blender doesn't save animation keyframe input (color/Value ...) in shader node with luxcore render engine.
From the blendluxcore Devs it is a blender issue.
1/ install luxcore render engine from here : https://luxcorerender.org/download/
2/ in blender switch to Luxcore engine
3/ add a shader matte (or any shader)
4/ animate any shader value of your choice.
Nandeya charles (sharlybg) renamed this task from Blender 2.8 external renderer shader node bug to Blender 2.9 external renderer shader node bug .Sep 14 2020, 6:45 PM
Nandeya charles (sharlybg) created this task.
Juan Gea (juang3d) awarded a token.Sep 15 2020, 5:23 PM
Juan Gea (juang3d) added a subscriber: Juan Gea (juang3d).
This is kind of super important for any third party render engine
Richard Antalik (ISS) changed the task status from Needs Triage to Confirmed.Sep 16 2020, 5:34 PM
Richard Antalik (ISS) added a project: Nodes & Physics.
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
I can confirm, that preview is not updated when scrubbing timeline, Render is updated.
@Nandeya charles (sharlybg) do you have link to ticket in luxcore bugtracker?
Nandeya charles (sharlybg) added a comment.EditedSep 16 2020, 10:17 PM
As it is a blender bug i didn't open a bug issue on Luxcore bug tracker. But just in cases it is needed here is the link to the BlendLuxcore bug tracker : blendluxcore bug tracker
Richard Antalik (ISS) changed the task status from Confirmed to Needs Information from User.Sep 17 2020, 2:55 PM
You said "From the blendluxcore Devs it is a blender issue." So I assumed you reported this and they said it's bug in Blender, I also confirmed this on that basis. It would definitely help if we knew why this is bugh in Blender.
Since I have not triaged this really, we need to have another look. But to triage this issue we need example file that demonstrates the bug. I would assume that the node or tree is not doing something sometimes, but I need to know that exactly. Having example file is best because both of us can test if things are working correctly.
Sorry if I misunderstand something.
Nandeya charles (sharlybg) added a comment.Sep 17 2020, 6:30 PM
Sorry for late reply. Here is the file :
Tried the file in Blender 2.83LTS + Blendluxcore 2.4 official and it work. But Blender 2.83LTS + Blendluxcore 2.5 don't.
will test blender 2.9 official + 2.5 and 2.4 blendluxcore.
Richard Antalik (ISS) added a comment.Sep 17 2020, 6:46 PM
Thanks for example file, but that is not quite what I meant. This would require us to work not only with Blendr code, but also with Luxcore's. We should not need to use Luxcore to demonstrate this bug if it is bug in Blender.
Nandeya charles (sharlybg) added a comment.Sep 17 2020, 6:46 PM
Tested with Blender 2.9 + Blendluxcore 2.4 and it work.
Richard Antalik (ISS) added a subscriber: Simon Wendsche (BYOB).EditedSep 17 2020, 7:21 PM
@Simon Wendsche (BYOB) Hi, I don't know if you know about this issue, but since you are Luxcore dev can you share some information that can help us track and fix this?
Simon Wendsche (BYOB) added a comment.Sep 17 2020, 10:06 PM
With Blender 2.9 and latest BlendLuxCore v2.5 I can not reproduce the problem.
Nandeya charles (sharlybg) added a comment.Sep 18 2020, 10:43 AM
Blender 2.9 and latest BlendLuxCore v2.5 same issue with two files :
and this one
Simon Wendsche (BYOB) added a comment.EditedSep 18 2020, 12:53 PM
You should include a description what the actual bug is.
I thought the problem was that keyframes can't be set on properties of custom nodes, or don't show up in the UI.
However, the actual problem is that keyframes on custom node properties are either not evaluated or not updated when doing a final render of the full animation with Ctrl+F12. Rendering individual frames with F12 works as expected, and the keyframes show up in the UI as yellow/green on the node properties.
I can reproduce the issue with Blender 2.9 and BlendLuxCore v2.5 (have not tested other versions of either).
Simon Wendsche (BYOB) added a comment.Sep 18 2020, 1:33 PM
I have put together a minimal script to show the issue without requiring the installation of the BlendLuxCore addon:
  • Open scene in Blender 2.9
  • Press "run script" in the text editor on the left
  • Hover the mouse over the float property of the node on the right, and set a keyframe with I
  • Advance 10 frames, change the value (e.g. to 20) and set another keyframe
  • Go back to frame 1, and again advance 10 frames. Check the console, it will show an output like this:
frame: 1
my_float_prop: 1.0
frame: 2
my_float_prop: 1.6515774726867676
frame: 3
my_float_prop: 3.3978052139282227
frame: 4
my_float_prop: 5.925926208496094
frame: 5
my_float_prop: 8.923182487487793
frame: 6
my_float_prop: 12.076818466186523
frame: 7
my_float_prop: 15.074075698852539
frame: 8
my_float_prop: 17.602191925048828
frame: 9
my_float_prop: 19.34842300415039
frame: 10
my_float_prop: 20.0
  • Render with Ctrl+F12
  • Check the console again, it will show an output like this:
Saved: 'C:\tmp\0001.png'
 Time: 00:00.41 (Saving: 00:00.00)
frame: 2
my_float_prop: 20.0
Saved: 'C:\tmp\0002.png'
 Time: 00:00.01 (Saving: 00:00.00)
frame: 3
my_float_prop: 20.0
Saved: 'C:\tmp\0003.png'
frame: 4
my_float_prop: 20.0
Saved: 'C:\tmp\0004.png'
frame: 5
my_float_prop: 20.0
Saved: 'C:\tmp\0005.png'
frame: 6
my_float_prop: 20.0
Saved: 'C:\tmp\0006.png'
 Time: 00:00.00 (Saving: 00:00.00)
frame: 7
my_float_prop: 20.0
Saved: 'C:\tmp\0007.png'
frame: 8
my_float_prop: 20.0
Saved: 'C:\tmp\0008.png'
frame: 9
my_float_prop: 20.0
Saved: 'C:\tmp\0009.png'
frame: 10
my_float_prop: 20.0
Saved: 'C:\tmp\0010.png'
frame: 10
my_float_prop: 20.0
So, in a frame_change_post handler, the custom property is animated correctly, but during final render animation it is not updated.
Nandeya charles (sharlybg) added a comment.Sep 21 2020, 1:45 PM
Any update about this issue fix ?
Richard Antalik (ISS) added a comment.Sep 28 2020, 6:50 AM
@Simon Wendsche (BYOB) Thanks a lot for minimal example file. I checked this in 2.90 and I can confirm this issue, but I can't reproduce in latest 2.91.
@Nandeya charles (sharlybg) can you download latest development build from https://builder.blender.org/download/ and check if problem is still there?
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).Oct 7 2020, 11:38 AM
Any update here, @Nandeya charles (sharlybg) ?
Nandeya charles (sharlybg) added a comment.Oct 14 2020, 6:50 PM
Lastest 2.91 and luxcore give black screen in render viewport so it is impossible to test.
Nandeya charles (sharlybg) added a comment.EditedOct 14 2020, 7:05 PM
Official 2.90.1 and blendluxcore 2.4 Work :
Official 2.90.1 and blendluxcore 2.5 Don't Work in Final render : But strangelly work in viewport.
Richard Antalik (ISS) closed this task as Archived.Oct 15 2020, 6:54 PM
Richard Antalik (ISS) claimed this task.
I with provided example script I still have no issues in 2.91. Also if the issue truly boils down to what is in provided example file, then it is not the same issue as T71908.
Since I can reproduce issue in 2.90 and not in 2.91 I will close this report now. If this bug can be reproduced in 2.91 please comment here or open new report.
