Maniphest T80914
Addon - Batch Rename Datablocks - Not searched
Closed, Duplicate
None
Jang, Hong-Tak (mongpic)
Sep 18 2020, 2:41 AM
  • Add-ons (Community)
Alaska (Alaska)
Philipp Oeser (lichtwerk)
Operating system:
Graphics card:
Broken:
(example: 2.79b release)
It says to search and use it, but it cannot be searched.
Jang, Hong-Tak (mongpic) created this task.Sep 18 2020, 2:41 AM
Philipp Oeser (lichtwerk) added subscribers: Alaska (Alaska), Philipp Oeser (lichtwerk).Sep 18 2020, 1:00 PM
Try this:
In T76227#1008017, @Alaska (Alaska) wrote:
For those experiencing issues with some operators not showing up in the search operator, try these steps:
  1. From the top of Blender select Edit -> Preferences.
  2. From the list of tabs on the right, select Interface.
  3. Now enable the option Developer Extras.
  4. Save your preferences. Now you should be able to find the command you're looking for in the search operator.
This is just a temporary fix. As this task explains, almost everything in Blender should be updated so they're accessable in the search operator without adjusting settings. But until then, this is a work around.
But generally speaking, this is a duplicate of T76227: Make All Operators Accessible from Menus, will merge these reports.
Philipp Oeser (lichtwerk) closed this task as a duplicate of T76227: Make All Operators Accessible from Menus.Sep 18 2020, 1:00 PM
