Maniphest T80954
Rendering fire simulation outside caché range, crashes blender 2.90.0 when using Cycles.
Closed, Resolved
Carlos Troncoso (schmick)
Sep 19 2020, 8:24 AM
  • BF Blender
  • Nodes & Physics
Germano Cavalcante (mano-wii)
Richard Antalik (ISS)
Operating system: Ubuntu 20.04
Graphics card: GTX 1050Ti
Broken: 2.90.0
Worked: 2.83
When a scene with 250 frames, has a smoke/fire simulation in the 50-250 range, rendering any frame between 1 to 49 using cycles will crash blender with the following error.
terminate called after throwing an instance of 'openvdb::v7_0::ValueError'
  what():  ValueError: can't construct a dense grid with an empty bounding box
Aborted (core dumped)
Open blender
Create quick simulation with default cube.
Set simulation caché range to 50-250
Set simulation type to MODULAR
Bake simulation.
Render frame 150 on eevee: works
Render frame 10 on eevee: works
Change render engine to Cycles
Render frame 150 on cycles: works
Render frame 10 on cycles: crash.
Carlos Troncoso (schmick) renamed this task from Rendering fire simulation outside caché range, crashes blender when using Cycles. to Rendering fire simulation outside caché range, crashes blender 2.90.0 when using Cycles..Sep 19 2020, 8:24 AM
Carlos Troncoso (schmick) created this task.
Carlos Troncoso (schmick) added a project: Nodes & Physics.Sep 19 2020, 8:49 AM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Sep 22 2020, 9:23 PM
I tested it here but I can't reproduce the problem whether rendering with CPU or GPU :\
Operating system: Windows-10-10.0.18941 64 Bits
Graphics card: Radeon (TM) RX 480 Graphics ATI Technologies Inc. 4.5.13596 Core Profile Context 20.10.19.02 27.20.1019.2002
Carlos Troncoso (schmick) added a comment.Sep 22 2020, 9:26 PM
Might be a linux only issue.
Will test on a fresh 2.9 download and a snapstore version tonight.
Carlos Troncoso (schmick) added a comment.Sep 23 2020, 5:33 AM
Didn't work.
Got a fresh copy, deleted all userprefs, and still got
Richard Antalik (ISS) changed the task status from Needs Triage to Needs Information from User.Sep 28 2020, 11:52 AM
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
Please check if this issue exists in latest development build from https://builder.blender.org/download/
Carlos Troncoso (schmick) closed this task as Resolved.Sep 30 2020, 5:48 AM
Carlos Troncoso (schmick) claimed this task.
I downloaded "blender-2.91.0-e5aa9decb23f". Worked without crashing. Marking this as resolved. Thanks!
