Operating system: MacOSX 10.15.2
Graphics card: Radeon RX Vega 56 8 GB (eGPU)
Broken: Radeon RX Vega 56 8 GB
I have two images as planes with movie clips in them, both with alpha, aligned by Y axis. Camera looks at first, other as a background. When I wanted to add DoF so the background is blurred, I found that camera cannot do Depth of Field at all and blurs all objects at the same time orall objects are sharp.
Fully reproducible:
- Add an image as a plane, make it big, put away enough. Let's call it image A.
- Add a mesh cone.
- Make camera look at the cone's tip and let the image as a plane be at background image A visible
- Make DoF tareging cone so the cone is crisp, back image A is blurred just as expected.
- Add another image B as plane at the same distance as cone, but the image B is the same blurred as the background A.
If you switch to Cycles, all works as expected.
