Maniphest T80985
Texture 2.8 Bug - Transparent Images
Closed, Archived
Evan Wilson (EAW)
Julian Salerno (TricentricAnimations)
Sep 20 2020, 7:10 AM
  • BF Blender
Eugene Du (APEC)
Evan Wilson (EAW)
michael campbell (3di)
Robert Guetzkow (rjg)
Graphics card: Radeon(TM) 530 ATI Technologies Inc. 4.5.14523 Core Profile Context 24.20.12002.0
Broken: version: 2.90.0, branch: master, commit date: 2020-08-31 11:26, hash: rB0330d1af29c0
The textures that have no fill backgrounds (grass, flowers, hair etc.) are now black{F8901647}
Files:
Image of bug
Textures
Julian Salerno (TricentricAnimations) created this task.Sep 20 2020, 7:10 AM
Julian Salerno (TricentricAnimations) renamed this task from texture 2.8 bug to Texture 2.8 Bug - Transparent Images .Sep 20 2020, 9:11 AM
Eugene Du (APEC) added a subscriber: Eugene Du (APEC).Sep 20 2020, 11:54 AM
Did you change Blend Mode in Material to Alpha Hashed?
Eugene Du (APEC) added a comment.Sep 20 2020, 11:59 AM
Also if you attach scene with bunch of textures it better to Pack All in blend file and then upload here
michael campbell (3di) added a subscriber: michael campbell (3di).Sep 20 2020, 5:11 PM
@Julian Salerno (TricentricAnimations) Have you tried in todays daily build? It's unclear from the report, but I suspect you may be having the same problem described in https://developer.blender.org/T80684 whereby all texture nodes created during import which use png images were getting their colour socket connected to the principled alpha socket, instead of the texture node's alpha socket being connected to the pricnipled's alpha socket.
It's been fixed now for fbx. I don't think the obj importer is quite as advanced as the fbx importer, so it doesnt check if the imported texture is png, and therefore connects nothing to the principled's alpha socket.
Evan Wilson (EAW) closed this task as Archived.Sep 20 2020, 11:25 PM
Evan Wilson (EAW) claimed this task.
Evan Wilson (EAW) added a subscriber: Evan Wilson (EAW).
This report does not contain all the requested information, which is required for us to investigate the issue. This is 190 image texture files, no .blend, and no description of the steps to reproduce the issue. You say that they are now all black. Where they transparent before? If so, in what version of Blender?
Please submit a new report and carefully follow the instructions.
Robert Guetzkow (rjg) added a subscriber: Robert Guetzkow (rjg).EditedSep 20 2020, 11:43 PM
Adding to @Evan Wilson (EAW) s comment, please don't post that many texture files. Try to create a minimal example Blender project file with one object that shows the issue. The texture can be automatically packed into the .blend file if you enabled File > External Data > Automatically Pack Into .blend.
