Maniphest T81120
Crashes unexpectedly during playback animation
Closed, Archived
Richard Antalik (ISS)
Clarence K (Clarence)
Sep 24 2020, 6:19 AM
  • BF Blender
  • Nodes & Physics
Ankit Meel (ankitm)
Philipp Oeser (lichtwerk)
Operating system: macOS Catalina version 10.15.6
Graphics card: AMD Radeon Pro 5500M 8 GB
version 2.90
Blender Crashes during playback animation.
Animating physics, blender would crash unexpectedly. I was using Ian Huberts "jet engine" as a free asset. The rest of the 2 objects are a simple plane and square objects.
  • List Item (Physics settings) objects
Enable physics for - Rigid Body
Type - Active
Settings Mass - 500 kg/Dynamic/animated
Collisions Shape - Mesh
Crash Logs:
Related Objects
Mentioned In
T80994: Blender 2.91 Alpha make crash guide still
Mentioned Here
rBe340f943f500: Fix (unreported) install_deps: broken compilation of OIDN.
Clarence K (Clarence) created this task.Sep 24 2020, 6:19 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Sep 24 2020, 3:09 PM
Philipp Oeser (lichtwerk) added a project: Nodes & Physics.
Could you share the .blend file?
(this makes sure we are all on the same page)
Clarence K (Clarence) added a comment.Sep 25 2020, 12:42 AM
This comment was removed by Clarence K (Clarence).
Clarence K (Clarence) updated the task description.Sep 25 2020, 12:44 AM
Hi Philip, I've added the file on my original post above. Please check. Thanks,
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Triage.Sep 25 2020, 9:48 AM
Philipp Oeser (lichtwerk) changed the task status from Needs Triage to Needs Information from User.Sep 25 2020, 10:03 AM
Cannot reproduce a crash here.
Could you provide the crash log?
https://docs.blender.org/manual/en/dev/troubleshooting/crash.html
Clarence K (Clarence) added a comment.Sep 25 2020, 8:12 PM
I don't think I can reproduce the crash log, the window didn't show up when I reopened blender, but I was able to check the system/memory&limits and its set to undo steps of 32, and 0 on undo memory limit. I tried closing the application again and the crash log report didn't show up.
Clarence K (Clarence) updated the task description.EditedSep 26 2020, 7:22 AM
I found the crash logs. I posted it on the original post.
Also, I tried starting a new project to re create the same physics in animation. Unfortunately blender keeps crashing. Here's a new crash report log. MacBook is up to date as of today, version 10.15.7 OS Catalina.
Clarence K (Clarence) updated the task description.Sep 26 2020, 7:24 AM
Clarence K (Clarence) added a comment.Sep 26 2020, 7:56 AM
I tried restarting a new project but it keeps crashing.
Philipp Oeser (lichtwerk) changed the task status from Needs Information from User to Needs Triage.Oct 1 2020, 9:10 PM
T80994: Blender 2.91 Alpha make crash guide still also crashes in blf_kerning_cache_find, not sure if this is related
Ankit Meel (ankitm) updated the task description.Oct 9 2020, 4:59 PM
Ankit Meel (ankitm) added a subscriber: Ankit Meel (ankitm).Oct 9 2020, 6:42 PM
I opened the file, hit play and played upto 250 frames. It didn't crash. Is there a step that I missed to do ?
rBe340f943f500a06b25 macOS Mojave.
Ankit Meel (ankitm) changed the task status from Needs Triage to Needs Information from User.Oct 9 2020, 6:42 PM
Richard Antalik (ISS) closed this task as Archived.Nov 14 2020, 5:08 AM
Richard Antalik (ISS) claimed this task.
Richard Antalik (ISS) added a subscriber: Richard Antalik (ISS).
