blender bug gpu.cmd---
blender_debug_gpu_glitchworkaround----
blender_debug-log-------
blender debug output ------
| Sofonias Ferede (sofonias456) | |
| Oct 16 2020, 7:56 PM |
| Robert Guetzkow (rjg) |
Unfortunately your bug report is missing important information which are required to investigate the issue. Please read this guide, it may help you write a bug report that allows us to fix your problem. We expect all bug reports to follow the submission template.
Please provide system information (operating system, GPU, driver version), affected Blender version, most recent Blender version that worked properly, a short and precise description of the issue, step by step instructions to reproduce it and, if relevant, a minimal .blend file that showcases the problem.
Three of the four files you've uploaded are just batch scripts copied from Blender's installation. They are supposed to be executed to create log files, the batch scripts themselves don't contain any helpful information. Open Blender's installation directory and double click on the blender_debug_gpu.cmd. This will start Blender in debug mode and create log files. Try to make Blender crash again. Once it crashes the Windows Explorer should open and show you up to two files (debug log and system information). Add them to your bug report by clicking on the upload button as shown in the screenshot below. Please also upload the crash log located in C:\Users\Owner\AppData\Local\Temp\blender.crash.txt.
Since the crash occurred in the graphics driver the likeliest causes are either an outdated graphics driver or a GPU that is below the minimum requirements. In order to run Blender with an AMD graphics card it has to have the GCN first generation or later microarchitecture, otherwise it is not supported.
