Operating system:
Graphics card:
Broken: (example: 2.80, edbf15d3c044, master, 2018-11-28, as found on the splash screen)
I usually Extrude in Blender by pressing E and then button for their respective axis. For e.g if i want a face to extrude in y_axis , i simply press E and then y and it worked perfectly earlier. But this time the face is extruded in some other direction and i know i can use Other option to complete my project but this way is so simple and i used to it
- - start blender latest version
- go to edit mode
- go into front view and select the face which is on y-axis
- the Press E to extrude and Y to extrude in y axis
- face will extrude in some other axis **
