Maniphest T82139
Sculpt Mode TODO tasks
Needs Triage, NormalTO DO
Pablo Dobarro (pablodp606)
Oct 27 2020, 1:14 PM
  • Sculpt, Paint & Texture
Daniel Bystedt (dbystedt)
Julien Kaspar (JulienKaspar)
Paul Larson (GeorgiaPacific)
Tiago Cruz (tiagoffcruz)
Torrent (Torrent)
Vyacheslav (hitrpr)
Tokens
"Like" token, awarded by Rubens91."Like" token, awarded by hitrpr."Like" token, awarded by Harti."Love" token, awarded by mindinsomnia."Love" token, awarded by gilberto_rodrigues."Party Time" token, awarded by Jules."Like" token, awarded by Imaginer."Love" token, awarded by johnsyed."Like" token, awarded by GeorgiaPacific.
This task keeps a list of approved tasks related to Sculpt Mode that can be considered as TODOs or missing functionality in the current design.
Gesture tools
  • Make Hide Box tool use the new sculpt API and gesture operator
  • Face Set Line Gesture
  • Color Fill Gestures
  • Line Trim Gesture
  • Normal Orientation for trimming tools
  • Poly line gestures
  • Mask Gradient Gesture tools
  • Lasso, Line and Poly line hide tools
Sculpt Vertex Colors
  • Sculpt vertex colors gradient Tool
  • Combined Color Coords Undo step
  • Pick Sculpt Vertex Color from other object with the sample color operator
Transform tool
  • Transform Tools TODO: T80392
Brush tools
  • Expose minimum size and size pressure smoothness for all brushes
  • Implement area normal/center stabilizer
  • Make Grab active vertex grab from original coordinates instead of PBVH deformed coordinates
  • Pinch perpendicular mode for crease
Viewport
  • Update matcaps to include a separate specular pass
  • Render Face Sets as contour lines
Elastic Deform
  • Pinch elastic deform mode
  • Multi scale twist-scale-pinch for elastic deform
Filter tools
  • Support textures in mesh filter
  • Unify filter strength with brush strength
Cloth Sculpting
  • Expose solver properties as Sculpt properties (iterations, delta...)
  • Make use collisions options global
  • Implement SDF collisions
  • Implement collisions plasticity
  • Elastic Deform cloth brush
  • Support cloth deformation target with dynamic area in all brushes
  • Support cloth deformation target for the transform tool
Boundary brush
  • Split the internal and boundary falloff into two different falloff
  • Let boundary falloff offset be smaller than 1
Sculpt Mode options
  • Store radial and tiling symmetry in meshes
  • Enable "Delay Viewport Updates" by default
  • Add a separate property to meshes to store if they should use flat/smooth shading in sculpt mode, without modifying their normals
Multires
  • Multires Delete Lower
  • Multires refit/rebase
  • Key map changes to support switching up/down subdivisions
  • Hide remeshers and Dyntopo when multires is active
  • Preview the current/total number of subdivisions in the viewport
  • Optimize Unsubdivide dissolve operation when creating the base mesh
Pablo Dobarro (pablodp606) created this task.Oct 27 2020, 1:14 PM
Paul Larson (GeorgiaPacific) awarded a token.Oct 27 2020, 6:14 PM
Paul Larson (GeorgiaPacific) added a subscriber: Paul Larson (GeorgiaPacific).
Torrent (Torrent) added a subscriber: Torrent (Torrent).Oct 27 2020, 6:21 PM
Where is the draw sharp with pinch? I can't see it.
Tiago Cruz (tiagoffcruz) added a subscriber: Tiago Cruz (tiagoffcruz).Oct 27 2020, 6:57 PM
babajan (johnsyed) awarded a token.Oct 27 2020, 9:22 PM
Ryan Inch (Imaginer) awarded a token.Nov 11 2020, 11:38 PM
Julian Mohr (Jules) awarded a token.Nov 20 2020, 12:39 PM
Gilberto Rodrigues (gilberto_rodrigues) awarded a token.Nov 25 2020, 1:23 AM
Mindinsomnia (mindinsomnia) awarded a token.Nov 26 2020, 3:01 PM
Steffen Hartmann (Harti) awarded a token.Feb 1 2021, 8:47 PM
Vyacheslav (hitrpr) awarded a token.Jan 13 2022, 7:00 AM
Vyacheslav (hitrpr) added a subscriber: Vyacheslav (hitrpr).
Ruben Dario Espinel Mora (Rubens91) awarded a token.Jan 17 2022, 7:40 PM
Philipp Oeser (lichtwerk) changed the subtype of this task from "Report" to "To Do".Mar 11 2022, 8:50 AM
