Maniphest T83207
Inconsistent Bevel Thickness when switching Between Vector and Free Curve Handle Types
Closed, Duplicate
None
Joe Williamsen (jwilliamsen)
Nov 30 2020, 1:37 AM
  • BF Blender
  • Modeling
Germano Cavalcante (mano-wii)
Graphics card: GeForce RTX 2070/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
When using the curve geometry options to make "walls" from curves (Extrusion + Bevel settings), switching from a "vector" handle to a "free" handle causes the wall thickness to increase - which is not expected.
Open the attached file
(you should already be in Top view, Edit Mode for Curve 3, and the control point on the far right selected)
Pick Curve 3 if it's not already picked
Go to Edit mode (should already be in Edit mode)
Grab any of the (straight) Vector handles and move them. Notice that the wall on that side of the handle immediately becomes significantly thicker. It would be ideal if the thickness remained even.
Joe Williamsen (jwilliamsen) created this task.Nov 30 2020, 1:37 AM
Germano Cavalcante (mano-wii) added a project: Modeling.Dec 2 2020, 8:21 PM
Germano Cavalcante (mano-wii) updated the task description.
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Dec 2 2020, 8:35 PM
This appears to be a limitation for 3D curves.
There must be some geometric limitations that make it impossible to achieve uniform thickness for all 3D curve shapes.
But you can work around the problem with 2D curve.
So I don't think this is a bug, but a technical limitation.
Germano Cavalcante (mano-wii) closed this task as a duplicate of T80979: Account for curvature in curve to mesh node.Dec 2 2020, 11:36 PM
