Graphics card: GeForce GTX 550 Ti/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 391.35
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
Worked: not found
While doing UNDO(for simple or modal operator) in mesh edit mode, vertices tweaks revert to start positions but custom property dont revert to initial value.
In object mode undo works correctly.
Yotube Video
Open .blend file.
Switch to editmode.
Run script in script window(alt+P).
Run operator in View3D side panel(named "TEST UNDO").
Change value for operator in "Adjust last operation window". Selected verts moving with center point defined in custom property.
Make undo. Verts reverting but custom property(that is changed by operator from vertices center position) is not.
