Graphics card: Quadro P1000/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 452.56
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
When I load a file with the Stereoscopy option enabled, there is a flashing checkerboard in the background (ONLY in the right eye view) in the 3D Viewport as I move around the scene. It does not matter if I'm in red/cyan anaglyph mode or in top/bottom mode. (The issue may appear in the other 3D modes, but I didn't check.)
There are a couple workarounds to make this checkerboard go away. One is to select the scene's Camera object and move around the scene briefly in the 3D Viewport. It does not matter if the 3D Viewport’s N panel -> View -> View Lock option is checked or not; as long as I select the Camera object and move in the 3D Viewport, the problem goes away until I start Blender again. The other way I've gotten this issue to go away is to set the Viewport Shading to either Material or Rendered, then back to Solid. (Setting the Viewport Shading to Wireframe does not fix the issue.)
- Open or create an EEVEE project with the following properties (or use my attached Blender file):
- A camera object and an object
- 3D Viewport with Viewport Shading set to Solid
- Output Properties tab -> Stereoscopy checkbox checked
- Output Properties tab -> Stereoscopy -> Stereo 3D checked
- Window -> Set Stereo 3D -> Display Mode: Anaglyph, Anaglyph Type: Red-Cyan
- 3D Viewport -> N Panel -> View tab -> View Lock -> Camera to View checked
- Have the Camera Perspective selected and move around the 3D Viewport. I use a 3D mouse (a 3DConnexion SpaceMouse) and can see the flashing checkerboard the whole time while moving (that is what is on my screen capture video). If you use the X/Y/Z spinner in the upper right hand corner or use View -> Navigation -> Walk Navigator, you will only see the checkerboard once you stop moving.
See the following screen capture: https://youtu.be/tmpGW7xsgBU
