Operating system: Ubuntu 18.04
Graphics card: Unknown
Tried in two different versions:
Broken: Daily build of 2.92.0 alpha from December 21, 00:12:38- d283a093d664
Broken: Blender 2.90.1
If a python script registers a frame_change_post handler that modifies the body property of a text object, then any transform animations on that text object are sometimes ignored during animation rendering but work fine when previewing in the editor viewport.
This is not consistent, I have a scene with some objects where this is a problem and others where it is not a problem. I'm not sure what other conditions are required for this to happen.
It is consistent within the example blend file I have attached, however. The file contains a pair of text objects that both have transform animations, and custom property animations that the python script depends on.
See video of steps to reproduce here: https://youtu.be/9d5D-RYvGkg
