Maniphest T84390
Cache folder auto-deletes files
Closed, Archived
None
Jack Schaberg (Jay_Blend)
Jan 5 2021, 12:53 AM
  • BF Blender
  • Nodes & Physics
Robert Guetzkow (rjg)
Graphics card: GeForce RTX 2060 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.38
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
After baking a smoke simulation between 200 and 400 frames, the files created in the cache file sometimes just disappear.
  1. I set up a pretty simple simulation using Quick smoke and then tweaked settings per a tutorial.
  2. Bake simulation.
  3. Afterwards, I move the camera around and insert keyframes so as to make sure I get the entire simulation in the frame.
  4. During this process, my computer lags a bit because of size of the simulation.
  5. All of the sudden, it quite lagging... because the baked files have seemingly deleted themselves.
  6. I go into the folder one minute, and all the files are there. I go in the next minute, and they're gone, and I have to start from scratch.
7.I changed the location of the cache file from its default location a few times, but that doesn't help.
  1. This doesn't always happen. Just maybe 1 out of 3 times I bake the simulation.
Jack Schaberg (Jay_Blend) created this task.Jan 5 2021, 12:53 AM
Jack Schaberg (Jay_Blend) added a comment.Jan 5 2021, 12:58 AM
I just found this thread and read through it: T56083
Seems like a similar problem. If this is still a known issue, I'll try following the fix described by Hermann Voßeler
Robert Guetzkow (rjg) changed the task status from Needs Triage to Needs Information from User.Jan 5 2021, 12:00 PM
Robert Guetzkow (rjg) added a subscriber: Robert Guetzkow (rjg).
Please provide an example file where baking and then keyframing the camera causes the problem. The settings for the simulation may be relevant here, in particular those related to the cache.
I was not able to reproduce the problem.
Robert Guetzkow (rjg) added a project: Nodes & Physics.Jan 5 2021, 12:01 PM
Robert Guetzkow (rjg) added a comment.Jan 13 2021, 12:25 PM
@Jack Schaberg (Jay_Blend) Please add the requested information otherwise we cannot investigate the issue.
Jack Schaberg (Jay_Blend) added a comment.Jan 15 2021, 12:13 AM
My apologies. I have been super-busy and unable to reproduce the problem in the limited time I've had. I'll try again and submit a file if I can get it to crash (after downloading the newest build).
Thanks.
Jack Schaberg (Jay_Blend) added a comment.Jan 15 2021, 1:53 AM
After moving the camera around on this file for about 10 minutes, the smoke and the cache files suddenly disappeared.
Robert Guetzkow (rjg) added a comment.EditedJan 23 2021, 12:30 PM
@Jack Schaberg (Jay_Blend) Do you mean you are moving the camera object or navigating in the 3D viewport?
Jack Schaberg (Jay_Blend) added a comment.Jan 23 2021, 2:16 PM
Yes, this happens when moving the camera object around the scene to get various angles of the simulation and setting new keyframes for the camera object.
Robert Guetzkow (rjg) added a comment.Feb 9 2021, 10:09 PM
So far I haven't been able to reproduce the issue. The current version of Blender 2.91.2 and 2.92 and 2.93 are in development. Please check if these versions still exhibit this problem.
Robert Guetzkow (rjg) added a comment.Feb 20 2021, 11:36 PM
@Jack Schaberg (Jay_Blend) Could you please check if this problem still occurs in the current versions? Perhaps it is already fixed or we are missing a particular steps that triggers this behavior.
Jack Schaberg (Jay_Blend) added a comment.Feb 20 2021, 11:54 PM
Sorry for the delay. I have not been able to reproduce this using the newer builds, so I imagine the issue should be closed.
Robert Guetzkow (rjg) closed this task as Archived.Feb 21 2021, 12:01 AM
Good to hear. Should you be able to reproduce the issue again, please let us know and create a new report.
