Maniphest T84492
Wireframe input node incorrectly shows triangles where there should be none...
Closed, Duplicate
None
Anton Raves (Memento)
Jan 7 2021, 2:17 PM
  • BF Blender
Robert Guetzkow (rjg)
Operating system: Linux-5.9.16-200.fc33.x86_64-x86_64-with-fedora-33-Thirty_Three 64 Bits
Graphics card: AMD JUNIPER (DRM 2.50.0 / 5.9.16-200.fc33.x86_64, LLVM 11.0.0) X.Org 3.3 (Core Profile) Mesa 20.2.6
Broken: version: 2.92.0 Alpha, branch: master, commit date: 2021-01-06 23:54, hash: rBa9c607e60ebf
When using a Wireframe input node in the shader, it will show triangles there were there are non, but quads and / or n-gons. How to get here: Set your "Blender Viewport" to "Rendered" view, create a default cube, move it to X, Y, Z = 0, 2, 0, leave its material to the default Blender material. Create another default cube, leave that at its origin and create a new material with it selected, move into the "Shader Editor" and replace the default "Principled BDSF" shader with a "Wireframe input node" one.
The second cube is showing triangles where it has none, they should be quads, or am I grievely mistaken...?
Anton Raves (Memento) created this task.Jan 7 2021, 2:17 PM
Robert Guetzkow (rjg) closed this task as a duplicate of T67328: Fix wireframe node to no longer show implicit tessellation.EditedJan 7 2021, 2:28 PM
Robert Guetzkow (rjg) added a subscriber: Robert Guetzkow (rjg).
The Wireframe node works with the triangulated geometry. This is not a bug in Blender and documented in Blender's manual.
The Wireframe node is used to retrieve the edges of an object as it appears to Cycles. As meshes are triangulated before being processed by Cycles, topology will always appear triangulated when viewed with the Wireframe node.
