Maniphest T84875
Sculpt: Remesh: Voxel Size Edit Keymap conflicts with Redo Keymap
Closed, Duplicate
None
Ovionis (Phigon)
Jan 20 2021, 1:10 AM
  • BF Blender
Ovionis (Phigon)
Philipp Oeser (lichtwerk)
TheRedWaxPolice (TheRedWaxPolice)
Graphics card: GeForce GTX 770/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 457.30
Broken: version: 2.93.0 Alpha, branch: master, commit date: 2021-01-18 23:28, hash: rB09c7c6389052
Interactively setting the voxel resolution of a sculpt is keymapped to Shift+R
Repeat Last operator is keymapped to Shift+R
Remesh takes priority over Repeat but while it can ONLY run in the 3D view, Repeat is blocked from being ran by for example moving the mouse to a different area to activate it.
Since Remesh is disabled during Dyntopo, Repeat will then be able to run in sculpt mode again.
Those are two factors of this issue. The big issue being these two operators share the same keymap, which then creates conflicts of what pressing the key does.
Ovionis (Phigon) created this task.Jan 20 2021, 1:10 AM
Ovionis (Phigon) added a comment.Jan 20 2021, 1:20 AM
I originally believed this was an issue with my configuration because I thought I added Shift+R - Repeat manually to my keymap, when it turns out it's a default thing.
To bypass this issue, I switched all the Remesh operators to E, because those are unused.
I row reset the remesh operators to R and moved Repeat to Shift+Z.
The reason for this is Shift+Z just toggles to Wireframe, and I use Z-Click (from Pie Menu on Drag), which makes that redundant.
Additionally, Undo/Redo are with Z key, and I also added a keymap for Undo/Repeat History to Z as well, so it makes sense to just have the Redo with Z as well.
My keys for those if you're curious, are Ctrl+Alt+Z = Undo History; Ctrl+Alt+Shift+Z = Repeat History.
TheRedWaxPolice (TheRedWaxPolice) added a subscriber: TheRedWaxPolice (TheRedWaxPolice).Jan 20 2021, 3:36 AM
Ovionis (Phigon) added a comment.Jan 20 2021, 6:06 AM
@ an authority figure
I don't have the option to mark as duplicate.
Philipp Oeser (lichtwerk) added a subscriber: Philipp Oeser (lichtwerk).Jan 20 2021, 9:51 AM
It is indeed the same as T76655: Sculpt Mode: Edit Voxel Size hotkey conflict, will merge these reports.
Philipp Oeser (lichtwerk) closed this task as a duplicate of T76655: Sculpt Mode: Edit Voxel Size hotkey conflict.Jan 20 2021, 9:51 AM
