Maniphest T84937
"Number of points in cache does not match mesh"
Closed, Archived
None
Lauris (Lauris.V)
Jan 21 2021, 5:15 PM
  • BF Blender
  • Sculpt, Paint & Texture
Aaron Carlisle (Blendify)
Aidan Davey (ShadowDragon)
Lauris (Lauris.V)
Pablo Dobarro (pablodp606)
Philipp Oeser (lichtwerk)
Graphics card: GeForce GTX 1650/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 461.09
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash: rB5be9ef417703
[When i click on the bottom (3) cushions for sitting on and go in to sculpt mode it goes all spiked and say's "Number of points in cache does not match mesh" ]
[Click on 1 of the sitting cushions and go into sculpt mode]
[Based on the default startup or an attached .blend file (Blend file)]
Thanks!
Related Objects
Lauris (Lauris.V) created this task.Jan 21 2021, 5:15 PM
Aidan Davey (ShadowDragon) added a subscriber: Aidan Davey (ShadowDragon).Jan 21 2021, 8:30 PM
Philipp Oeser (lichtwerk) closed this task as Archived.Jan 22 2021, 2:36 PM
Philipp Oeser (lichtwerk) added projects: Sculpt, Paint & Texture, Documentation.
Philipp Oeser (lichtwerk) added subscribers: Pablo Dobarro (pablodp606), Aaron Carlisle (Blendify), Philipp Oeser (lichtwerk).
Two issues here:
  • [1] Your cloth cache is outdated, you need to rebake it:
(this probably happened because something changed in the stack prior to the cloth modifier -- possibly the subd levels on the subdivision modifer above?)
If you do this, you'll get rid of the Number of points in cache does not match mesh" error as well as the spikes going to sculptmode.
  • [2] Sculpting with active physics modifiers is not going to give you expected results. You will alter the underlying original mesh, but this will not get feed into the simulation result, so this is not going to work out.
There might be (better) ways to communicate this [in form of documenting this or giving a popup warning in the UI], but this would not be considered a bug.
Workflow wise, you are advised to keep a copy of the sim object, but for further sculpting, apply the modifiers, see https://youtu.be/4h097E4pRCw?list=PLjEaoINr3zgGgS-N9Ews90bDAYYLoP0NO&t=986
CC @Aaron Carlisle (Blendify)
CC @Pablo Dobarro (pablodp606)
Think we have to close this though, since this is not considered a bug.
For user requests and feedback, please use other channels: https://wiki.blender.org/wiki/Communication/Contact#User_Feedback_and_Requests
For more information on why this isn't considered a bug, visit: https://wiki.blender.org/wiki/Reference/Not_a_bug
Omar Emara (OmarSquircleArt) mentioned this in T101060: Render is broken.Sep 14 2022, 12:40 PM
