Maniphest T85042
"Key Modifier" key-binds send single event trigger along with the expected modified event trigger.
Closed, Duplicate
None
Nathan Clark (Neigh)
Jan 25 2021, 1:11 PM
  • BF Blender
Germano Cavalcante (mano-wii)
Operating system: Darwin-19.6.0-x86_64-i386-64bit 64 Bits
Graphics card: AMD Radeon Pro 5700 XT OpenGL Engine ATI Technologies Inc. 4.1 ATI-3.10.18
Broken: version: 2.91.0, branch: master, commit date: 2020-11-25 08:34, hash: rB0f45cab862b8
Custom key-binds using "Key Modifier - regular key pressed as a modifier" are sending the single event trigger as well as the modified event trigger.
Exact steps for others to reproduce the error:
Setting the key map item:
  • Open Blender preferences
  • Add a new key map item (for this example, identifier: wm.search_menu)
  • Leave the default "A"
  • Change from "Press" to "Release"
  • Click "Key Modifier" and press a regular keyboard key (for this example: F19)
Executing the shortcut
  • In the 3D viewport press F19-A
Result
  • wm.search_menu is triggered - search menu pops up.
  • object.select_all is ALSO triggered - all object in viewport are selected.
Expected result
  • Only wm.search_menu is triggered - Only the search menu pops up.
  • Key-binds that use the unmodified key press should not trigger.
Nathan Clark (Neigh) created this task.Jan 25 2021, 1:11 PM
Germano Cavalcante (mano-wii) added a subscriber: Germano Cavalcante (mano-wii).Jan 26 2021, 3:55 PM
This works like this by design. See this comment -> https://developer.blender.org/T68621#837961
So it's a known issue.
Germano Cavalcante (mano-wii) closed this task as a duplicate of T68621: Keymap: custom key modifiers work inconsistently.Jan 26 2021, 3:56 PM
