Graphics card: GeForce RTX 2070 SUPER/PCIe/SSE2 NVIDIA Corporation 4.5.0 NVIDIA 456.71
Broken: version: 2.91.2, branch: master, commit date: 2021-01-19 16:15, hash: rB5be9ef417703
I can only see the glow FX in the Render Result window. If rendering to an image sequence using Ctrl F12 or still image via python using write_still=True, there is no glow effect.
Open the attached Blend file
Check the render output path.
Set the Viewport to Rendered (to check the glow is working).
Press Ctrl F12 to render the 2 frame sequence.
Compare the file on disk to the Render Result image.
If the the result is consistent, you'll notice the glow is missing from the files on disk.
The result image doesn't export glow effect if the Film option is set to transparent.
